Rear Cab Support Repair
  • Replies 13
Got some POR-15 coming via Amazon. Gonna coat the floor pans.
Question......thinking about putting some Heat/Sound deadening on the floor. Maybe inside the doors. To quiet things down inside. Anyone have suggestion ?
I did see on a couple of You-Tube videos that some of the Box Stores carry  Heating Duct (Frost KIng) insulation they say works.
Also, some using Peel N Seal with some success.
Welcome any feedback .
I used the roof seal roll that Home Depot carries on my dime, seems to work fine, I'll use it on my 620 as well, $20 for the 26' roll, don't get the tar one, there's​ two, non tar is what you want.
  • 2 weeks later...
OK, thanks for the comments.
I had some time to work on the carpet.
Got a piece from J.C. Whitney it was supposed to fit the whole cab but what they sent me did fit the front area only so so... I did some trimming to get the front fit.
Now I'm at the "GLUE" or "NOT Glue" the carpet to the insulation ?
I can use the four screws that held the original rubber floor mats.
I've got some spray contact but if I tack the carpet to the insulation and ever need to take the carpet up I'd have a mess...
Appreciate feedback on this.
Taking your advise. I'm going to give it a try without Glue. Your right the center console, floor screws and the door sills on the sides should hold it in place.
That insulation is really slippery... like a damn sliding board.
Also thinking about covering the back of the cab from the floor to the bottom of the window.
Not sure if I want to use a thin fiberboard or just carpet it to.
