Lozer Posted June 2, 2017 Report Share Posted June 2, 2017 SO my carbs hit the hood ( kade with rx1 carbs) even with the silly honda hood spacer lift (i fucking hate) I'm curious if anyone has used 1/4" spacers to lift the body up a little higher. and if i do what would the conceivable negatives be. Quote Link to comment
flatcat19 Posted June 2, 2017 Report Share Posted June 2, 2017 Con...will need more lower. Pics of your engine? I think it would be ultimately easier to just trim the I take to get the carbs to sit lower. Quote Link to comment
Lozer Posted June 2, 2017 Author Report Share Posted June 2, 2017 Got coilovers so no big on lower. And intake is trimmed back to far as it is. I need to either fab an intake or get a bogg brothers one. Quote Link to comment
datzenmike Posted June 2, 2017 Report Share Posted June 2, 2017 Raising the body will raise the engine. Lower the engine by re drilling the engine mount bolt holes! But only good for 1/2" or so, or engine gets too close to the ground. Modify the intake to lower the cabs. 1 Quote Link to comment
Lozer Posted June 2, 2017 Author Report Share Posted June 2, 2017 It shouldn't raise the engine if I put a .25" spacer between the x member and chassis. Quote Link to comment
flatcat19 Posted June 2, 2017 Report Share Posted June 2, 2017 The more you move the crossover the more geometry of everything else changes. Can it be done to meet your needs? Sure. Could this easily turn into a headache? You bet. NVH nightmare, aisle 3. 2 Quote Link to comment
datzenmike Posted June 2, 2017 Report Share Posted June 2, 2017 What transmission you using? Quote Link to comment
Lozer Posted June 2, 2017 Author Report Share Posted June 2, 2017 Ka 5speed. 71c Quote Link to comment
Icehouse Posted June 3, 2017 Report Share Posted June 3, 2017 Like stated about it will move the relation ship between the inner tie rods and the LCA inner pivot making your car handle worse by increasing bump steer. 1 Quote Link to comment
thisismatt Posted June 3, 2017 Report Share Posted June 3, 2017 Roll the motor mounts over and have your passenger shift? 1 Quote Link to comment
hang_510 Posted June 3, 2017 Report Share Posted June 3, 2017 Pound a dent into the hood. That's why the PO did on mine to clear the valve cover on the LZ24. Quote Link to comment
datzenmike Posted June 3, 2017 Report Share Posted June 3, 2017 Ahh now I see the problem. I thought it was a custom manifold. Shorten the old intake manifold runners an inch or so and add trumpets. Probably a truck intake cut down would be a better choice. They are not curved like the sx intake. 1 Quote Link to comment
