Sunnygal Posted June 1, 2017 Report Share Posted June 1, 2017 I am trying to find front wheel hubs for my '78Datsun B210 GX. Any suggestions on other models or makes that may fit without modifications? Quote Link to comment
datsunfreak Posted June 4, 2017 Report Share Posted June 4, 2017 I am trying to find front wheel hubs for my '78Datsun B210 GX. Any suggestions on other models or makes that may fit without modifications? Any year B210 should be the same (1974-1978). Quote Link to comment
Sunnygal Posted June 4, 2017 Author Report Share Posted June 4, 2017 Thank you for the info. I am aware that these years will fit. My problem is locating a wheel hub. What I need to know is; are there are any other makes or models of any vehicles that are compatible with or without modification. Quote Link to comment
datzenmike Posted June 4, 2017 Report Share Posted June 4, 2017 Looks like the 610, 710, 810, S10, (first gen '77-'79 200sx) A10, ('78-'81 HL510) and the S110 (second gen '80-'81 200sx) all used the same hub. Quote Link to comment
datsunfreak Posted June 4, 2017 Report Share Posted June 4, 2017 are there are any other makes or models of any vehicles that are compatible with or without modification Also, changing out the struts could be a solution if you cannot find the right hub. And the upside is you also have the opportunity to upgrade your brakes at the same time. B) http://community.ratsun.net/topic/72041-1978-b210-with-280zx-brakesstrut-assembly/?hl=%2B280zx+%2Bstruts&do=findComment&comment=1490018 Quote Link to comment
