Brandon.fair Posted May 31, 2017 Report Share Posted May 31, 2017 My fuel line from the tank to the pump is rotten and I need to replace it. Problem is I don't know the diameter to purchase more. Can someone please inform me of the diameter. Also what's the best way to change it. It's cramped under there. 1 Quote Link to comment
Crytek89 Posted May 31, 2017 Report Share Posted May 31, 2017 You can just take the old line to NAPA/Lordco or any auto store really and they'll match it with what they have. 1 Quote Link to comment
Brandon.fair Posted May 31, 2017 Author Report Share Posted May 31, 2017 You can just take the old line to NAPA/Lordco or any auto store really and they'll match it with what they have. It my only vehicle so........ I dont think that will work 1 Quote Link to comment
Crashtd420 Posted May 31, 2017 Report Share Posted May 31, 2017 I'd say good chance it's 1/4 or maybe 3/8 metal lines. Not sure if the lines got bigger over the years.. by the sounds of it you don't have measuring caliper... Do you have any drills? Find a 1/4 and a 3/8 drill bit and compare to the line even disconnect a rubber line and see what fits.... 1 Quote Link to comment
Brandon.fair Posted May 31, 2017 Author Report Share Posted May 31, 2017 I'd say good chance it's 1/4 or maybe 3/8 metal lines. Not sure if the lines got bigger over the years.. by the sounds of it you don't have measuring caliper... Do you have any drills? Find a 1/4 and a 3/8 drill bit and compare to the line even disconnect a rubber line and see what fits.... It's the rubber lines that need replacing. But that sounds like it will work. 1 Quote Link to comment
fivetengarage Posted May 31, 2017 Report Share Posted May 31, 2017 Another way to check the hose size would be to fit an open end wrench onto the steel line. 1/4,5/16 and 3/8 are your common hose sizes. 2 Quote Link to comment
Crashtd420 Posted June 1, 2017 Report Share Posted June 1, 2017 Another way to check the hose size would be to fit an open end wrench onto the steel line. 1/4,5/16 and 3/8 are your common hose sizes. I generally just measure with calipers but I like that.. Never thought of that but ya that works without having to disconnect anything... 1 Quote Link to comment
Crytek89 Posted June 1, 2017 Report Share Posted June 1, 2017 Well, I just did mine this weekend (replaced fuel pump and filter) I don't recommend disconnecting the fuel line without putting a pair of vice-grips on the line as it'll spray everywhere and it sucks (experience). If I recall it'll be a 3/8in hose.. gimme a min and I'll find out. 1 Quote Link to comment
Crytek89 Posted June 1, 2017 Report Share Posted June 1, 2017 it's a 1/4in hose - if you want a sturdier hose ask for a fuel injected style - it'll handle up to 50psi and may give it a bit more life, cost will be a bit more but means you don't have to replace it anytime soon. 1 Quote Link to comment
Brandon.fair Posted June 1, 2017 Author Report Share Posted June 1, 2017 Thanks yall. Now I'm having another issue. I added tech-con. Now it won't idle. I had this problem before and I sprayed out the jets and that fixed the issue. Did that today and still won't idle. I have a new fuel filter. But need new hose to replace the filter but I can't get to the store bc it won't idle haha FML 1 Quote Link to comment
Brandon.fair Posted June 2, 2017 Author Report Share Posted June 2, 2017 Fuel filter replaced your correct with it being 1/4" I.D. and you'll need about two feet 1 Quote Link to comment
datzenmike Posted June 2, 2017 Report Share Posted June 2, 2017 The return line is larger diameter than the feed line. 2 Quote Link to comment
DeRo1979 Posted March 7, 2022 Report Share Posted March 7, 2022 Is the return line necessary? Can't it be capped? Pete Quote Link to comment
datzenmike Posted March 7, 2022 Report Share Posted March 7, 2022 If your vehicle comes with a return line you should keep it. It serves 2 purposes, it circulates cool fuel past the carburetor reducing the likelihood of vapor lock. (the boiling of fuel in the carburetor making hot restarts more difficult) Circulating the fuel also filters it over nd over keeping the tank and lines cleaner. The return line does have a restriction about the size of a large pin hole. If no restriction the gas would simply ignore the carburetor and follow the path of least resistance back to the tank. This is for the L20B but the Z24 is similar... Quote Link to comment
