GORILLARILLA21` Posted May 29, 2017 Report Share Posted May 29, 2017 My 70 510 has a rebel wiring 9+3 installed by the previous owner. I swapped the 510 and am working on the wiring. I have a alt. exciter wire that went from alt to fuse box with the l16 motor. It's on the same circuit as ignition switch accessory. I'm assuming the power supplied at this circuit is from the alt exciter wire not the ignition switch accessory? At least on this fuse box, all the power looks to share power on each of the three circuits.. I'm running a stand alone ecu with a wiring specialities harness/fuse box so the rebel fuse box will be a "auxiallry" body harness standalone with fuses. Do I splice into the wiring specialty connector at the alt and share the same alt exciter wire? Don't have a battery to test power.. maybe time to bring the power probe home from work.. Quote Link to comment
