Tikka Posted May 24, 2017 Report Share Posted May 24, 2017 So I fired up my 510. First time in 30 years. The rear carb was pouring gas and there seemed to be gas coming from the exhaust too. Next chance I get I'll check the plugs and ignition wires to make sure those pistons are firing. Is there anything else I should check? Quote Link to comment
datsunrides Posted May 24, 2017 Report Share Posted May 24, 2017 Probably stuck float valve. Quote Link to comment
Tikka Posted May 25, 2017 Author Report Share Posted May 25, 2017 Anyway of reaching it with gumout? I'd really like to avoid taking it apart. Never worked on Solex carbs before. After seeing all the gas that poured through I'm surprised it didn't free itself up. Quote Link to comment
KoHeartsGPA Posted May 25, 2017 Report Share Posted May 25, 2017 Step 1: remove both carbs and clean them up thoroughly, if you don't know how, find someone to help you, they have to be in optimum shape in order to operate properly, it's been sitting for 30 years, there aren't any short cuts here, even if you get it to run, it won't perform to it's potential and possibly ruin your motor if it's too lean. 1 Quote Link to comment
datsunrides Posted May 25, 2017 Report Share Posted May 25, 2017 It's only a few screws to take the float chamber off and clean it up. You could try tapping the fuel inlet nut lightly with something like the end of a screwdriver and see if that frees it up without disassembly. 1 Quote Link to comment
banzai510(hainz) Posted May 25, 2017 Report Share Posted May 25, 2017 my jet block would back out .open top and see if looks obvious accell pump diaphram may crack also and leak 1 Quote Link to comment
Tikka Posted May 25, 2017 Author Report Share Posted May 25, 2017 Thanks folks. I'll be getting under the hood again as soon as our weather permits. I have to work on it outside. Too many toys in the garage, no room. 1 Quote Link to comment
KoHeartsGPA Posted May 25, 2017 Report Share Posted May 25, 2017 Keep us posted and share some pics, please! 1 Quote Link to comment
Tikka Posted July 15, 2017 Author Report Share Posted July 15, 2017 Car is in the final stages. Carbs are getting their final tune. Should have it on the streets some time next week. 1 Quote Link to comment
Tikka Posted July 15, 2017 Author Report Share Posted July 15, 2017 [/url]">http:// [/url]">http:// [/url]">http:// http://s1174.photobucket.com [/url]">http://http://s1174.photobucket.com/user/tikka16/media/20160906_185631_zpsis9uibbe.jpg.html'> So here's a few 2 Quote Link to comment
Tikka Posted July 20, 2017 Author Report Share Posted July 20, 2017 Got the carbs on. Here's the before and after. Only problem is that now the rest of the engine looks like shit. Now its time to put her guts back in and get her cleaned up. Quote Link to comment
Tikka Posted July 20, 2017 Author Report Share Posted July 20, 2017 Oops!! Having trouble down loading pics again. Will post soon. Quote Link to comment
Tikka Posted July 20, 2017 Author Report Share Posted July 20, 2017 sorry aint workin Quote Link to comment
