Pabloairmale Posted May 22, 2017 Report Share Posted May 22, 2017 done this a million times in eletronic dist cars. i cant figure it out on a points set up. Is there a grounding issue or am i missing somthing here? ignition power(red), green wire to the neg side of coil, and black ground to the body. white not used( dash light) Quote Link to comment
datzenmike Posted May 22, 2017 Report Share Posted May 22, 2017 Points and electronic are basically the same. The coil - terminal is grounded by the distributor and the circuit opened when the plug is to be fired. This is the 'sense' wire on the tach. You can connect the White wire to the ignition Red power source. Doesn't really matter if the light is on during the day, you won't notice. Quote Link to comment
