captain720 Posted May 25, 2017 Report Share Posted May 25, 2017 I would just go to NAPA and get their mid grade or high end. As a general rule I don't buy the cheapest stuff unless you desire to replace it in the future (so don't shop at oreillys (sorry Lockleaf, I am sure yours is better than mine, but my oreilys has sold me good carb and choke cleaner, some coolant and some oil, other than that I have returned pretty much every thing else I bought there)). 1 Quote Link to comment
Lockleaf Posted May 25, 2017 Report Share Posted May 25, 2017 I'm well aware of how cheap much oreilly product is :). That being said, they do sell wix filters, which is who makes napa gold filters. So at least those are good. 1 Quote Link to comment
Brandon.fair Posted May 25, 2017 Report Share Posted May 25, 2017 Thank for the help guys. It is much appreciated. Maybe the secondaries are clogged too? I would spray them out too, and consider running some start tron through. But that is my unprofessional opinion. I have sprayed out the secondaries. No luck. (I assume the vertical brass tube in the back of float bowl with two holes in it is the secondary) I noticed it seems to do it in second gear the most. It revs fine in neutral or the the clutch pressed in. When it was stalling at idle it didn't have this problem it would run strong. 1 Quote Link to comment
Brandon.fair Posted May 26, 2017 Report Share Posted May 26, 2017 Could this be a mixture issue ? Quote Link to comment
