Stock 521 air intake, paint or PC?
  • Please log in to reply
12 replies to this topic
#1 d.p
d.p
  • Senior Member
  • PipPipPipPip
  • 1,162 posts
  • Cars:1971 521, 2018 M3
Posted 20 May 2017 - 06:30 AM
I thought about getting it PC'd but not sure I can replace the crumbling rubber seals.  So anyone have theirs done?  If so what did you do?
#2 MikeRL411
MikeRL411
    78 'n counting...
  • Senior Member
  • PipPipPipPipPip
  • 5,525 posts
  • Cars:67RL411, 90 240SX, 97J30T
Posted 20 May 2017 - 04:57 PM
I don't understand the excitement over powder coat!  After all it's nothing more than a thin coat of melted plastic.  Bond to the metal is dependent on surface preparation.  If you are going to do a proper clean and de-grease, why not do a proper prime and paint, it will last a lot longer.
#3 DanielC
DanielC
  • Senior Member
  • PipPipPipPipPip
  • 4,779 posts
Posted 20 May 2017 - 09:28 PM
1968 VW chrome blue is a very close match to the original color of the Datsun air cleaner housing.
#4 KELMO
KELMO
  • Senior Member
  • PipPipPipPipPip
  • 2,192 posts
  • Cars:71 Goon, 72 1200 coupe x 2, 69 F250 72 510 4DR Sedan 2003 Maxima 2014 Frontier 2012 Xterra
Posted 21 May 2017 - 04:17 AM
I have used Dupli-Color Pontiac Blue #1610 and would post a pic if not for PB being.....well you know the story.
NISMO: Nissan Impresses Sluts More Often
"Well, primer gray IS a color..." (quote: Kelmo's wife)
#5 d.p
d.p
  • Senior Member
  • PipPipPipPip
  • 1,162 posts
Posted 21 May 2017 - 07:34 AM
KELMO, you just sand/paint it yourself then?
#6 KELMO
KELMO
  • Senior Member
  • PipPipPipPipPip
  • 2,192 posts
Posted 21 May 2017 - 02:57 PM
Yes, sand, primer then paint.  I only did the exterior as I did not want to ruin the rubber bits on the inside.
This pic is the only one I could find and would have been taken shortly after painting the valve cover and air cleaner. The OE color is a shade or 2 more pale.
High temp primer and paint.
#7 d.p
d.p
  • Senior Member
  • PipPipPipPip
  • 1,162 posts
Posted 21 May 2017 - 04:53 PM
Looks great man!  I will probably do the same.
#8 KELMO
KELMO
  • Senior Member
  • PipPipPipPipPip
  • 2,192 posts
Posted 21 May 2017 - 07:21 PM
Thanks, at almost 10 years later it still  looks good.....well except for the scratches and dings I have put in it.
#9 d.p
d.p
  • Senior Member
  • PipPipPipPip
  • 1,162 posts
Posted 24 May 2017 - 09:40 AM
Got a link to the paint code or where I can buy this in a rattle can?  L51K?
#10 Crashtd420
Crashtd420
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,135 posts
  • Cars:1972 Datsun 521
Posted 24 May 2017 - 02:44 PM
I have a place in town that makes rattle cans from any paint code.... look for an automotive paint supplier near you....
Worse case text me the paint code and I'll get one made and send it to you if you need.... but you should be able to find a local place....
#11 zed1
zed1
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 557 posts
  • Cars:1966 PL520, 1969 Patrol L60, and 1970 240Z
Posted 24 May 2017 - 05:01 PM
Consider having Sherwin Williams color match the paint in their quart oil enamel gloss. Then use Preval (http://www.homedepot...n-267/202533738) to apply.
Keith
1969 Patrol L60
1965 Patrol L60 (parts provider)
1966 PL520
1970 240Z
1990 300ZX (sold 10/13)
#12 MikeRL411
MikeRL411
    78 'n counting...
  • Senior Member
  • PipPipPipPipPip
  • 5,525 posts
Posted 24 May 2017 - 05:10 PM
Worked for my 67 RL411!
#13 d.p
d.p
  • Senior Member
  • PipPipPipPip
  • 1,162 posts
Posted 24 May 2017 - 05:50 PM
I had to order a timing gasket kit so I just i ordered Pontiac blue from amazon as well. Will report back when it's all painted.
