Whiny alternator
  • Please log in to reply
17 replies to this topic
#1 BenR.T.
BenR.T.
    Newbie
  • New Members
  • Pip
  • 6 posts
  • Cars:73 620
Posted 18 May 2017 - 04:37 PM
Trying to diagnose a whine in my alternator in my 620 with a 1600 engine. I already replaced the old External regulator with a new solid state one. It is charging right around 14.5volts. Brand new Deka Battery.
I pulled out the new/rebuilt bosch alternator thinking maybe it had a bad diode, and just put it a brand new one (not rebuilt). I am still getting the same high pitched whine. It increases with the rpms and vice versa.
Is it possibly just bad wiring?
I am completely stumped, any help would be appreciated!
1973 "SSS" 620
Knifemaker - BRTbladeworks
#2 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,503 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 18 May 2017 - 04:55 PM
Inspect the belt. CAREFULY hold a bar of hard soap against the two faces of the belt that contact the pulleys. Keep away from the fan and watch you shirt sleeves!!!!
Posted Image
#3 BenR.T.
BenR.T.
    Newbie
  • New Members
  • Pip
  • 6 posts
  • Cars:73 620
Posted 18 May 2017 - 05:09 PM
It's a new belt too.
I am 99.99% sure its not belt noise. I've dealt with that on other vehicles, this sounds different, more like an electric motor running. Kind of a super charger whine.
1973 "SSS" 620
#4 kelowg
kelowg
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,060 posts
  • Cars:70 521 ka24e
Posted 18 May 2017 - 06:11 PM
Belt or belt alignment issue
#5 datzenmike
datzenmike
    KING RAT
  • 72,503 posts
Posted 18 May 2017 - 06:15 PM
Well, unplug the alternator. This will eliminate the charging aspect of the noise. (battery, regulator)
Posted Image
#6 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,582 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '05 Saabaru 92x, '07 Saab Trollblazer 97x
Posted 18 May 2017 - 07:10 PM
Is your fan clutch locked up?
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#7 BenR.T.
BenR.T.
    Newbie
  • New Members
  • Pip
  • 6 posts
  • Cars:73 620
Posted 18 May 2017 - 07:59 PM
Fixed fan. No clutch.
Ok, unplugged everything, still hear the noise.
Took the belt off and the noise is gone.
My thought is possible bearings in the waterpump? It does have a little play when I grab the pump pulley and wiggle it.
1973 "SSS" 620
#8 flatcat19
flatcat19
    Back in Black
  • Senior Member
  • 20,792 posts
  • Cars:Smaller. Better. Slower. Lower.
Posted 19 May 2017 - 09:08 AM
Stethoscope from HF can be had for less than $5.
You can't hang if your nuts haven't dropped...it's physics
#9 420n620
420n620
  • Senior Member
  • PipPipPipPipPip
  • 3,700 posts
  • Cars:68-510 goon,71-521,72-510 4dr, 78-620KC
Posted 19 May 2017 - 09:16 AM
to determining if it's the water pump or alternator making the whiny sound, take a metal rod or 3/8 drive extension/s, long enough so your face isn't getting slapped by the fan or what ever to make a stethoscope to get sound to travel through. Be careful to not get it into any moving parts. With engine running, take the metal rod and carefully put it on the alternator housing and put the other end up next to your ear, touching just before the ear opening, listen to the sound being transferred. Now carefully take the rod and put it close to the water pump housing and listen to the sound. Which one sounds the loudest ?
if it was your water pump, the bushing is on it's way out and you should see some weeping of anti-freeze coming out on the ground.
if it's the alternator, sometimes all you need to do is open it up, ( hope you know how to) and put a little grease on the bearings.
hope this helps, report back with your findings.
RAP IS LIKE SCISSORS, IT ALWAYS LOSES TO ROCK !!!
#10 Scgreen620
Scgreen620
  • Senior Member
  • PipPipPipPip
  • 693 posts
  • Cars:1978 datsun620
Posted 20 May 2017 - 10:48 PM
Make sure your alternator bracket is tight I just had a similar problem
#11 spdcrazy
spdcrazy
  • Senior Member
  • PipPipPipPip
  • 309 posts
  • Cars:30zxtt, Subaru wagon turbo, 71 Datsun 521, 76 pinto wagon
Posted 21 May 2017 - 05:02 AM
any chance of oil or coolant leaking down to it? if so, clean the alt, and spray some lube on the bearing maybe.
but it sounds like you are getting close to a solution!
#12 BenR.T.
BenR.T.
    Newbie
  • New Members
  • Pip
  • 6 posts
  • Cars:73 620
Posted 25 May 2017 - 01:03 PM
Changed the waterpump, which it needed anyway, but it's still making the sound.
I am sure it's something with the Alternator. The thing is, this the second replacement I have tried. The first was a Bosch rebuild, this is a brand new one. Both make the same exact sound.
What am I missing??
1973 "SSS" 620
#13 datzenmike
datzenmike
    KING RAT
  • 72,503 posts
Posted 25 May 2017 - 04:21 PM
Bosch is the problem.
Posted Image
#14 kelowg
kelowg
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,060 posts
  • Cars:70 521 ka24e
Posted 25 May 2017 - 04:50 PM
Make sure its the right alt and or voltage reg.  Part counter guys tend to screw up,have them look in actual catalogs
#15 BenR.T.
BenR.T.
    Newbie
  • New Members
  • Pip
  • 6 posts
  • Cars:73 620
Posted 25 May 2017 - 05:09 PM
Got the last one from Rock auto.
Brand new solid state VR as well.
Charge is right where it should be.
1973 "SSS" 620
#16 datzenmike
datzenmike
    KING RAT
  • 72,503 posts
Posted 25 May 2017 - 06:43 PM
Try turning high beams, heater and wipers on see if the wine is louder. Probably will be. The more output the alternator is obliged to produce, the more resistance to being turned by the engine. It's doing work and the bearings will make noise... they shouldn't, but stuff today is cheaply rebuilt with poor quality parts and labor.
Posted Image
#17 hang_510
hang_510
    too ol'skool
  • Senior Member
  • PipPipPipPipPip
  • 9,720 posts
  • Cars:71 2 door - LZ22 / 72 wagon - TBD
Posted 26 May 2017 - 08:08 AM
Put a new notch in the belt, or replace it.
I had the same noise and when I replaced the belt, it stopped, esp at high rpm.
Replace cheap,easy parts first. Also be sure all contacts are clean.
I've gone through 3 alternators on this motor, this was the first belt change.
"I can spend time working on the Dattos, or wasting money at the strip club. You make the call." :D
I'll put on chain mail and a dirt bike tire jock strap and drive it!!!!!
#18 datzenmike
datzenmike
    KING RAT
  • 72,503 posts
Posted 27 May 2017 - 08:02 AM
It may be normal to whine depending on the bearings that were used when re-built.
Posted Image
