Scgreen620 Posted May 6, 2017 Author Report Share Posted May 6, 2017 Does it only make the noise under load? The engine does tap when it's running but does it more when I accelerate hard Quote Link to comment
Scgreen620 Posted May 6, 2017 Author Report Share Posted May 6, 2017 Maybe you should read your other post.... you know the one you forgot you asked about. Seems you found the problem and fixed it... Maybe you just forgot this too????????????????????????????????????????????? fuck me. put the pipe down and get a SFM and some tools. mike-al Angelo ... I know I posted something similar about noises but the screeching noises are gone because I fixed it now it's a different problem .. The guy who rebuilt my engine left bolts loose all over the place and now I must tighten all my nuts and bolts ... Quote Link to comment
datzenmike Posted May 6, 2017 Report Share Posted May 6, 2017 he said tighten his nuts.... Well.... better start doing your own work. 1 Quote Link to comment
Scgreen620 Posted May 6, 2017 Author Report Share Posted May 6, 2017 When it comes to internals in the engine I usually chicken out .. Lol but " to get shit done you gotta do it your self" Quote Link to comment
Scgreen620 Posted May 6, 2017 Author Report Share Posted May 6, 2017 he said tighten his nuts.... Well.... better start doing your own work. Mike you should watch a guy named "AVE". On you tube Canadian guy very funny likes to fuck around with tools and what not .. Reminds me of you a bit with all that knowledge Quote Link to comment
Scgreen620 Posted May 7, 2017 Author Report Share Posted May 7, 2017 Got the feeler gauges at harbor freight a couple of guys on you tube that do this I'm going to try to attempt it! Quote Link to comment
Stoffregen Motorsports Posted May 7, 2017 Report Share Posted May 7, 2017 The engine does tap when it's running but does it more when I accelerate hard This doesn't sound like a valve noise. Rod bearings and exhaust leaks get louder with increased throttle input. 1 Quote Link to comment
datzenmike Posted May 7, 2017 Report Share Posted May 7, 2017 Tapping that doesn't get louder but only speeds up with vehicle speed is likely one or more loose valve clearances. Loose valve lash makes noise constantly, weather you are driving hard or easy. Set the valve lash and see. This can be fixed by adjusting them. Eliminate this first and move on. This doesn't sound like a valve noise. Rod bearings and exhaust leaks get louder with increased throttle input. Pre ignition can also make noise when accelerating hard under load. Timing may be out, wrong plugs... easy fix if it is. Quote Link to comment
