Scgreen620 Posted May 4, 2017 Report Share Posted May 4, 2017 Noob question I finally got a oem tach and I can finally see how high I can riiipp it ... Only problem I'm having when I floor it my engine starts to make a clattering noise almost like it didn't have oil ...just wondering what can cause that noise ... There is oil in the engine btw way thanks Quote Link to comment
racerx Posted May 4, 2017 Report Share Posted May 4, 2017 Did you adjust your valves Quote Link to comment
datzenmike Posted May 4, 2017 Report Share Posted May 4, 2017 Don't you already have a post on this???? .... http://community.ratsun.net/topic/71358-l20b-engine-noises/ .... why not make good use of it?????? Suggestions were made in it did you follow through on any of them? 2 Quote Link to comment
kelowg Posted May 4, 2017 Report Share Posted May 4, 2017 Or is it shifter rattling? Quote Link to comment
banzai510(hainz) Posted May 4, 2017 Report Share Posted May 4, 2017 dist is worn or going out of time maybe put a timming light on there. fuel filter starvation Quote Link to comment
racerx Posted May 4, 2017 Report Share Posted May 4, 2017 Didn't u have that engine rebuilt? Take it back to them see what they say. Quote Link to comment
Stoffregen Motorsports Posted May 4, 2017 Report Share Posted May 4, 2017 Don't you already have a post on this???? .... http://community.ratsun.net/topic/71358-l20b-engine-noises/ .... why not make good use of it?????? Suggestions were made in it did you follow through on any of them? Yes, lots of suggestions were made in the previous thread. Did you try any of them? 1 Quote Link to comment
racerx Posted May 5, 2017 Report Share Posted May 5, 2017 All quiet on the western front Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 Lol sorry guys I forgot I asked this ... Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 It is rebuilt if it's the one about the screeching noise yes I did fix it ... It was the alternator being loose .... Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 Or is it shifter rattling? no the shifter isn't rattling Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 Didn't u have that engine rebuilt? Take it back to them see what they say. I did ....... that fool don't even want to touch it since he only gave me a year guarantee and now it's over Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 dist is worn or going out of time maybe put a timming light on there. fuel filter starvation I know there is gas I think it's even running rich Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 Need to check the timing.. Maybe that's off what's the normal time? Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 Would I have to be a pro to adjust my valves ? Quote Link to comment
Draker Posted May 5, 2017 Report Share Posted May 5, 2017 Would I have to be a pro to adjust my valves ? No.. it's very simple. 1 Quote Link to comment
Scgreen620 Posted May 5, 2017 Author Report Share Posted May 5, 2017 No.. it's very simple. Where can I get the valve gap tool? Not sure what it's called never done this Quote Link to comment
Draker Posted May 6, 2017 Report Share Posted May 6, 2017 They are feeler gauges. Get them at any tool store or maybe even parts store. You need a 14 and 17mm wrench. 10mm for the valve cover. 2 Quote Link to comment
racerx Posted May 6, 2017 Report Share Posted May 6, 2017 Go on youtube, i think mklotz shows how to or search on this forum or get a get a manual. What helps is to shave the 14'll wrench to make it fit better. Also remove your batter, if your valve gasket is leaking buy one before u adjust. 1 Quote Link to comment
flatcat19 Posted May 6, 2017 Report Share Posted May 6, 2017 Feeler gauge set can be had at HF for less than $5. 1 Quote Link to comment
KoHeartsGPA Posted May 6, 2017 Report Share Posted May 6, 2017 Does it only make the noise under load? Quote Link to comment
datzenmike Posted May 6, 2017 Report Share Posted May 6, 2017 Maybe you should read your other post.... you know the one you forgot you asked about. Seems you found the problem and fixed it... I think I found the problem tho I checked the alternator once again and noticed that the alternator bolts from the bottom of the alternator were loose... Tightened them no more noise ....fuck (slaps forehead) what I'll do is take it to autozone and get a new one just say the bearing is fucked or something Maybe you just forgot this too????????????????????????????????????????????? fuck me. put the pipe down and get a SFM and some tools. Quote Link to comment
