willz Posted May 1, 2017 Report Share Posted May 1, 2017 New bulbs, new flasher, turn signal switch from a working vehicle which I've cleaned up, new dialectic grease and made sure all the connections are soldered correctly. Running lights all work No blinkers at all, not in the front, not in the back, neither side. The lights light up when the running lights are on, but I'm getting no flash out of them. No click on the relay either I am missing the hazard switch in the column, could this be the issue? I wouldn't think the flasher from the hazard switch would be tied in with the turn signals directly so I am at a loss Quote Link to comment
Scgreen620 Posted May 1, 2017 Report Share Posted May 1, 2017 Check the relay/flasher I would try swaping those out first Quote Link to comment
willz Posted May 1, 2017 Author Report Share Posted May 1, 2017 They're brand new Quote Link to comment
Roadster-ka Posted May 1, 2017 Report Share Posted May 1, 2017 Turn signals receive power thru hazard switch Quote Link to comment
willz Posted May 1, 2017 Author Report Share Posted May 1, 2017 Well crap... is there any way to bypass that? Quote Link to comment
datzenmike Posted May 1, 2017 Report Share Posted May 1, 2017 The turn signals are disconnected when the 4 way is turned to ON. The turn signals are connected when the 4 way is turned to the OFF position. Find the 4 way switch plug and jumper or join the two solid Green wires together. This will connect the power from the fuse box to the turn flasher unit. 1 Quote Link to comment
willz Posted May 2, 2017 Author Report Share Posted May 2, 2017 I'm having a hard time finding the 4 way switch, where is it normally located or look like? Quote Link to comment
willz Posted May 2, 2017 Author Report Share Posted May 2, 2017 Would this be the plug for the hazard switch? Quote Link to comment
datzenmike Posted May 2, 2017 Report Share Posted May 2, 2017 New bulbs, new flasher, turn signal switch from a working vehicle which I've cleaned up, new dialectic grease and made sure all the connections are soldered correctly. Running lights all work No blinkers at all, not in the front, not in the back, neither side. The lights light up when the running lights are on, but I'm getting no flash out of them. No click on the relay either I am missing the hazard switch in the column, could this be the issue? I wouldn't think the flasher from the hazard switch would be tied in with the turn signals directly so I am at a loss I'm having a hard time finding the 4 way switch, where is it normally located or look like? You said it was missing. Find the harness plug that has... Lt Green/Black Lt. Green/Red Lt. Green/Black Blue wire Green Green/Red 2 Solid Green.... join these together Quote Link to comment
willz Posted May 2, 2017 Author Report Share Posted May 2, 2017 Saweeeeet. I'll just run pins over. That was the correct plug Quote Link to comment
