Drive shaft
  • Please log in to reply
3 replies to this topic
#1 fern01
fern01
    Newbie
  • New Members
  • Pip
  • 1 posts
  • Cars:620 pick up
Posted 27 April 2017 - 07:40 PM
Having problems with my drive shaft on my 620 pick up was told the bearing was rounded out and I may need to rebuild the whole thing. He said it was gunna be about 300 anybody have experience with this?
#2 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,339 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 27 April 2017 - 08:37 PM
I imagine the problem is vibration under load?
The bearing seldom goes bad but the rubber surround does rot away. For $300 you could buy a whole new drive shaft. The replacement kit is much less... if you can find one.
Take it to another shop, they will likely tell you a different story.
 Probably this rubber isolation doughnut...
Or do you mean the U joint? There are three of them about $30 each.
Posted Image
#3 Crashtd420
Crashtd420
  • Senior Member
  • PipPipPipPip
  • 1,705 posts
  • Cars:1972 Datsun 521
Posted 27 April 2017 - 09:08 PM
Either way $300 sounds about right if you go that route...
Thats what it cost me for a full recondition of my 521 driveshaft..
Labor, 3 ujoints, new carrier bearing,and balanced....
they should be balancing it too for that price...
Side note if you have to separate the driveshaft at all after balance it has to go back together the same way it was balanced
#4 Scgreen620
Scgreen620
  • Senior Member
  • PipPipPipPip
  • 693 posts
  • Cars:1978 datsun620
Posted 14 May 2017 - 05:20 PM
If your drive shaft has given you problems several times you should replace but if it's your first time just buy "u" joints
