Adjustable cam gear in US???
  • Please log in to reply
26 replies to this topic
#1 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,202 posts
  • Cars:77 Datsun 620, 73 Datsun 620
Posted 21 April 2017 - 04:01 AM
Does anyone stock an adjustable cam gear that fits an L20b in the US???
I need one that actually adjusts.  I just tried installing one with 8 holes last evening.  I can't get to the setting I need.  The funny thing is that I get the same 106 degrees at settings 1,2,3, and 4 gives me 114.  A,B, C, D are all obviously way off, and I can't skip a chain tooth to get there either.  This is checked reading .050" down each side of peak, always checked while rotating CW to account for chain slack.
Thanks for any leads, a sale is guaranteed!
#2 Doctor510
Doctor510
  • Senior Member
  • PipPipPipPip
  • 718 posts
  • Cars:Many 510's
Posted 21 April 2017 - 06:44 AM
106 degrees of what?   BTW, ALL L series motors use the same gear  Sounds like the 8 hole unit you have is NOT a NISMO unit but rather a modified stock gear.
#3 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,122 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 21 April 2017 - 07:28 AM
For what you're doing, I would not run and adjustable gear. NOTORIOUS for coming loose at sustained RPM's
Just drill out the hole in the gear ind use a cam degree bushing. They are rock solid and stay where you set them.
#4 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,202 posts
Posted 21 April 2017 - 08:32 AM
106 Intake centerline.  I'm trying for 107, 110,
I ordered an adjustable gear out of Japan this morning.  If I can pinpoint a couple settings that work on the dyno, I can drill stock gears to match what the adjustable gear is set to very easily, so I don't even have to use a bushing.
I also plan on modifying a "fixed" timing chain tensioner, given how short our races are.  That would allow us to try cam timing changes on the course in a matter of minutes.
Isn't the Nismo gear a modified stock gear?  Assumptions are a dangerous thing.  The big problem is that we don't know who is modifying them, and how many people/shops are doing it.
All of this is required due to the radical cam I'm playing with.  The guys at Schneider Cams said it was the most extreme 4 cylinder cam design they've ever ground, which means it had to be ground off-center from a normal grind to provide enough meat for the lobes without running out of hardened material.  I'll have to break it in with light valve springs, then install something a little stiffer to be able to sustain the high rpms I need without valve float.  I'm pretty sure 225 over the nose isn't going to cut it.
#5 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,122 posts
Posted 21 April 2017 - 09:06 AM
Why replace the bushing? Consider that the stock cam bolt torques to about 170#/ft, which will clamp everything in place.
I'm getting really excited to see your finished product. And I'd love to see you run it at Bonneville.
#6 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,202 posts
Posted 21 April 2017 - 09:31 AM
Given the issue I had in our test motor with the cam dowel walking out into the gear, I'm not taking chances on anything.  I want a solid gear on the race motor so that nothing can move or be moved.  The adjustable gear is a tool to make that happen.
I'm excited too, but we're still a few weeks from hearing this thing run.  More if cam timing isn't the only issue that arises.  And I have other irons in the fire so to speak, so a few of those projects need to be addressed in between all the assembly fun.  At least last night I test fit the 3.89 ring and pinion into the Detroit locker and clearances look great!  It was just a simple carrier swap in the N2 housing along with some new bearings.  Add some magic "special sauce" and it should be very, very low rolling resistance.
#7 G-Duax
G-Duax
    prickly in San Antonio
  • Senior Member
  • PipPipPipPip
  • 1,076 posts
  • Cars:73 620 & 90 Toyota Cressida
Posted 21 April 2017 - 12:44 PM
To drop some parasitic drag, run a single #35 timing chain ?
Modern kart chain (NOT industrial) doesn't use a master link, and can take 50 hp being driven from a 9 tooth engine sprocket.
"All of a sudden it started making noise, then started losing power. I limped the car home and tried to get it up the driveway, the engine just died."
Why do people do this?
A $100 tow bill is never as much as the extra damage you cause by trying to "limp the car home".
Don't be that person !
#8 Doctor510
Doctor510
  • Senior Member
  • PipPipPipPip
  • 718 posts
  • Cars:Many 510's
Posted 21 April 2017 - 02:03 PM
I don't know where you are getting the info on the gear changing the Cab lobe separation angle, the gear will change the torque/HP band.  The Nismo Gear is NOT a re-drilled stock unit, Google for the Nismo specs/  even the stock settings in holes, 1,2 & 3
#9 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,202 posts
Posted 23 April 2017 - 09:10 AM
510guy,  where did I ever mention changing the LSA?  I'm trying to dial in the intake centerline.  Intake lobe.  #1 intake.  And yes I'm trying to optimize my power band/rpm range for the cam I designed.
Maybe you should read the build thread I have going in the 620 section.  http://community.rat...d-speed-record/
As far as Nismo's gear, I don't really care what it is or where its from.  I have to assume they don't make it, as they don't make most of the gear in their catalog.  Maybe none of it?  As far as I know they could be buying parts from you.  No idea.  Don't care.  I just know the gear I purchased with 8 holes in it is seriously made wrong, and it came in the same generic type package you see from Nissan.  The vendor who sold it to me promptly offered to replace it, so I'm guessing its a known issue.
#10 Xnke
Xnke
    Hall Monitor
  • Members
  • PipPipPip
  • 213 posts
  • Cars:'72 S30
Posted 26 April 2017 - 06:50 PM
The Nismo gear works fine-but it's fiddly and just isn't as nice as the Kameari gear.
I've *never* had a properly torqued (use a damn torque wrench!) cam gear come loose or the adjustable cam gear loose it's grip and slip.
#11 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 71,759 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 26 April 2017 - 07:28 PM
The stock cam sprocket has 4 degree increments per hole 1, 2, 3. So 8 degrees advance starting on the #1 hole. Assuming #1 is the TDC center of the cam.
Each cam tooth is 9 degrees. So if on the #2 hole (advance 4 degrees) and remove a tooth you have -9 +4 = -5. There are a lot of different combinations you can get but only on the stock Nissan sprocket.
Posted Image
#12 bananahamuck
bananahamuck
    S&S chicken/rice
  • Senior Member
  • 13,539 posts
  • Cars:Cleopatra does the nasty.
Posted 26 April 2017 - 09:39 PM
http://www.thezstore...ic12f02/10-2042
Says they stock it but i don't know for sure ,, they have 800 number though
So somehow while i was driving back from Eaglerock swap meet i somehow caused YOU to post this,,,, do really think members on this site are that stupid to believe i caused it??
http://community.rat...un-for-a-while/
Yeah i guess you do,,
BTW ,,,, the first person to call you a pussy,,,, ya might wanna check out his ethnicity ,, cuz i don't think it's what you think it is there snowflakeboy
..........................I shall call it, narclops.
#13 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,202 posts
Posted 27 April 2017 - 04:28 AM
I have a new stock gear to play with from Cloyes.  Tomorrow the one arrives from Japan, if I'm here to sign for it.  One way or another, I should be able to have it sorted before the weekend is out.  I'll post what I find.
Mike, keep in mind that 9 degrees (per tooth) at the cam reads as 18 degrees at the crank where all measurements are taken. Cam moves at half speed so all measurements are doubled.  You always degree the cam from the crank to get more precise measurements.  This means a 3 degree jump at the cam is a mile at the crank.  Frustrating.
#14 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,246 posts
Posted 27 April 2017 - 12:02 PM
the Cloyes  I never liked as one cant see the timming marks as the view hole is in the wrong spot. for the stock initial set up
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
#15 G-Duax
G-Duax
  • Senior Member
  • PipPipPipPip
  • 1,076 posts
Posted 27 April 2017 - 01:36 PM
The Tomei is a good one also, pretty much the same basic design as the Kameari.
There was one out of Japan that only had 4 bolts, on a very small bolt circle.
I don't think I would run one of those.
$150 for a Kameari is a great price !!
#16 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,202 posts
Posted 28 April 2017 - 04:23 AM
The Kameari gear should arrive today.  BTW $167 with 2 day shipping from RHD Japan.  It took them 3 days for them to ship however, so 6 days total, ordered over the weekend.
#17 Mattndew76
Mattndew76
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 3,898 posts
  • Cars:Datsun 1200 Coupe
Posted 08 May 2017 - 07:03 AM
I had a Kameari timing gear in house a while back and made some solid models of it from solidworks.
After talking with Peter Mcdonell (https://www.instagra...termcdonnell65/)  about using them, and I decided to not make them. He recommended that the Kameari adjustable cam gears be inspected after every use if a person was going to use one.
An idea doesn't work unless you do.
#18 G-Duax
G-Duax
  • Senior Member
  • PipPipPipPip
  • 1,076 posts
Posted 08 May 2017 - 11:03 AM
Want to share why ?
#19 Mattndew76
Mattndew76
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 3,898 posts
Posted 09 May 2017 - 09:04 AM
Want to share why ?
The customers he had come to him with problems was from catastrophic failures from the Kamaeri cam gears. Its why he stated that inspections should be done before a run and after. They are not items you can install, set, and ignore.
#20 G-Duax
G-Duax
  • Senior Member
  • PipPipPipPip
  • 1,076 posts
Posted 09 May 2017 - 11:10 AM
I have never had one slip, and never had any external cam pulleys slip.
But then again, I know how to put things together......
In any form of racing, or in all of things dealing with life, the intelligence of the people involved can be charted on a graph.
And it will always be a bell curve, with a most of people in the bottom half, then decreasing numbers of people as the brain power increases.
And some people think they can build a race engine, and never look at it, while others do a complete tear down after every event,
