Cary Posted April 17, 2017 Report Share Posted April 17, 2017 Hello, I am repairing a z24i that has bent valves. In tearing everything down I noticed there is no way to match up the crank pulley. The tab that screws into the block is missing. As messed up as this in, I am not just pulling the head but doing the timing chain cover too. I want to be 100% when I get the head back from the shop Quote Link to comment
datzenmike Posted April 17, 2017 Report Share Posted April 17, 2017 I call it a timing scale. Usually on the alternator side on the timing cover above the oil pump. It's saw tooth with numbers and the notch on thelargest crank pulley is lined up with it for ignition timing and setting TDC. Quote Link to comment
Cary Posted April 17, 2017 Author Report Share Posted April 17, 2017 Yep that's it and I have an empty screw hole where it mounted. As soon as I read up on posting pictures I will post them. Wonder why auto parts stores don't show it as available Quote Link to comment
datzenmike Posted April 17, 2017 Report Share Posted April 17, 2017 Find another Z series engine and scoop it off that. '80-'82 A10 (HL510) Z20 engine '80-'83 S110 200sx Z20 and Z22 engine '81-'86.5 720 with Z20/22/24/24i gas engine '86.5-'88 D21 Hardbody (Z24i engine) '86-'88 Nissan Vanette Z24i engine Earlier L20Bs maybe, I'll look up the part number and application when I get home. Quote Link to comment
KELMO Posted April 17, 2017 Report Share Posted April 17, 2017 13502-W0400 Indicator-Timing mounts on the passenger side of the block. Looked this up for a Z24 in a 720 Truck (shows the same # for L20B in a 720 also). Quote Link to comment
