geistnoahg Posted April 15, 2017 Report Share Posted April 15, 2017 Hi there Ratsun, I'm in need of help with finding a VCV for my 720. Mine is broken and I'd need a new one or a used one that still works. Can anyone help me with links to buy one, or even one for me to buy if anyone has one laying around? Thanks guys, Noah Quote Link to comment
datzenmike Posted April 15, 2017 Report Share Posted April 15, 2017 Good place for a want ad.... http://community.ratsun.net/classifieds/category/4-engine/?sort_key=date_added&sort_order=desc Best bet is one from another truck. Wrecking yard, most likely. Quote Link to comment
thisismatt Posted April 15, 2017 Report Share Posted April 15, 2017 This? Try contacting the seller if so... http://www.ebay.com/itm/NORS-Nissan-Datsun-EGR-Valve-Datsun-720-Pick-Up-14956-16E00-/232215558928?hash=item3611203b10%3Ag%3AD3gAAOSwcUBYTCAG&vxp=mtr&nma=true&si=VYwf6bNOrJIJ10uGiJmAbPZ6RAA%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 Quote Link to comment
datzenmike Posted April 15, 2017 Report Share Posted April 15, 2017 Not that. The VCV is not electrical just two vacuum lines. Under heavy load intake vacuum opens an air leak into the vacuum advance line to the distributor, retarding the timing slightly. Quote Link to comment
geistnoahg Posted April 15, 2017 Author Report Share Posted April 15, 2017 Thank you Dazenmike! I'll be sure to post this in the classifieds! Quote Link to comment
Rjawm Posted April 15, 2017 Report Share Posted April 15, 2017 Is this the correct part? Here is a link to the part highlighted above https://www.nissanpartsdeal.com/parts/nissan-valve-vacuum-cl~22363-d1700.html Part # 22363-D1700 The other vaccuum switch next to it in the pic, 14955M, is a thermal switch so I didn't think that was it. Just in case it is, here's the link to it https://www.nissanpartsdeal.com/parts/nissan-thermal-valve~14890-u6700.html Part # 14890-U6700 The numbers in the pic are just for look up by the parts guy, the links I posted are to the actual parts with the correct part numbers. Both parts are for use on a Z24. Hope that helps. Also found this one https://www.nissanpartsdeal.com/parts/nissan-valve-control~14920-w8800.html Part # 14920-W8800 Between the two pics you can probably see where the lookup codes make it a PITA to make sure it's the right part lol Edited to include Nissan part numbers clearly in the post. Quote Link to comment
datzenmike Posted April 15, 2017 Report Share Posted April 15, 2017 Top picture is the VCV. The full part number is Nissan # 22363-D1700 used on '85 and up California equipped emissions. If they have one about $80. Quote Link to comment
Rjawm Posted April 15, 2017 Report Share Posted April 15, 2017 Thanks for the clarification Mike. Agreed on the if one can be found. Courtesy Nissan has it listed only as a discontinued part, tends to make me think it'd be pure luck to find a NOS one. Quote Link to comment
datzenmike Posted April 15, 2017 Report Share Posted April 15, 2017 Well a hail Mary.... Ask the Nissan dealer if they will memo all dealerships to check their inventory for one ordered but not used. They probably wouldn't mind getting it off the list. Quote Link to comment
geistnoahg Posted April 16, 2017 Author Report Share Posted April 16, 2017 Thanks you guys! I really appreciate the help! I'll call around to the dealerships in my area to see if they have one, hopefully, in stock. Quote Link to comment
datzenmike Posted April 16, 2017 Report Share Posted April 16, 2017 Wrecking yards. '85 and up will have them. Quote Link to comment
