76datto Posted April 4, 2017 Report Share Posted April 4, 2017 This is my truck im swapping a d21 ka in 3 Quote Link to comment
76datto Posted April 4, 2017 Author Report Share Posted April 4, 2017 the only issue im having is that the oil pan is hitting against the torsion bar. Quote Link to comment
Draker Posted April 4, 2017 Report Share Posted April 4, 2017 Coil overs or chop the pan? Good luck on the rest of the swap. 2 Quote Link to comment
flatcat19 Posted April 4, 2017 Report Share Posted April 4, 2017 There is a 2wd D21 being parted on our local CL. Let me see if I can find the add. If you can't find a 2wd pan to swap on you'll need to massage that pan to fit around the bars. 3 Quote Link to comment
flatcat19 Posted April 4, 2017 Report Share Posted April 4, 2017 There is this... https://kpr.craigslist.org/pts/6051633105.html The other ad I found is no longer there. 1 Quote Link to comment
]2eDeYe Posted April 4, 2017 Report Share Posted April 4, 2017 Re-posting this here for reference :) Did you use the d21 KA,2 wheel drive pan? Yes sir I'm using the whole d21 ka. But I'm just gonna notch the oil pan so it clears the torsion bar 4x4 pan is asymmetric and bulges to the side. That is a funky ass pan! Interesting, I did not know the 4x4 pan was like that. I may have a new pan in the works if all goes well. Would you be able to measure you pan for me? 1 Quote Link to comment
]2eDeYe Posted April 4, 2017 Report Share Posted April 4, 2017 That is a badass looking truck :cool: 2 Quote Link to comment
hobospyder Posted April 4, 2017 Report Share Posted April 4, 2017 That is a badass looking truck :cool: same colour as paisos. I kept getting confused last year 2 Quote Link to comment
Rhino13 Posted April 4, 2017 Report Share Posted April 4, 2017 I remember seeing that thing, super clean truck! 1 Quote Link to comment
KoHeartsGPA Posted April 4, 2017 Report Share Posted April 4, 2017 There is a 2wd D21 being parted on our local CL. Let me see if I can find the add. If you can't find a 2wd pan to swap on you'll need to massage that pan to fit around the bars. You'll also need to get the pick up tube when you get the 2wd pan. 1 Quote Link to comment
