Datsun B210 - LZ23, 5 spd.
  • Please log in to reply
38 replies to this topic
#21 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,302 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 15 July 2017 - 03:24 PM
Cocksuckers!!!!
(just wanted to say that)
Posted Image
#22 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
  • Cars:'78 620, '76 B210, '65 320
Posted 25 July 2017 - 11:06 PM
Here's the LZ23 all reassembled and prepping for fitment into the B210
It's worth mentioning again that a 510 crossmember does not allow you to "swap an L series right in" ... sure, it sits in there, but it's about 5-6" too far forward.. radiator wont properly fit and im sure that the weight distribution would be fucked.
anyway, in doing this modification i lowered the engine 3/4" and also moved it back 3" ... so far, im happy with it. Oil pan may be an issue and engine may need to be lifted 1/4".
yes. those are hockey puck motor mounts. no, the plates i made are not properly installed yet. this was the initial fitment test before I complete any more work and waste time.
(fyi use Imgur for new pic hosting. fast and way easier than photo bucket)
Here is the "adapter plate" i made up. It's very simple and probably not the best way to do this. But... it's simple. This isn't a race car.
I used the PL510 cross member. i cut the center out and made a custom square tube center that allows me to go front sump. I used a front sump oil pan and pickup tube from an imported L18 with efi ... it's what was sitting around. A10 oil pan will also work for front sump.
I'm happy (so far) with firewall fitment.
gcahCP7.jpg?1
stock 510 square port exhaust fits perfect
side draft clear the brake booster, too. Note, my manifold has a bend in it. if this manifold is not used, the side drafts may not fit.
still sitting very close to factory lean (some say 12 deg, some say 15 deg....)
#23 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 26 July 2017 - 05:16 AM
It's 12o 'by the book'.
Posted Image
#24 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 26 July 2017 - 05:45 AM
Great, so it's fine where it's at.
#25 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 26 July 2017 - 12:10 PM
It would have to be way out to affect the float in the carb or the shifter.
Posted Image
#26 Dguy210
Dguy210
    Service Manual Technician
  • Senior Member
  • PipPipPipPipPip
  • 2,518 posts
  • Cars:'74 B210, '71 1200 (project), for sale '84 Benz 300SD.
Posted 26 July 2017 - 07:06 PM
Well damn, nice work there. You basically made a 510 flipped crossmember there. Are you running a swaybar? I'd think a KA 510 or maybe even a 1200 swaybar might fit. Adaptor plate looks easy too. This definitely opens up the possibility of different oil pans too.
#27 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 27 July 2017 - 05:03 AM
Yeah, it's practically a flipped crossmember. However, it's small diameter and it sits a little further back, that way I can lower the engine and also push it back a little.
#28 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 20 August 2017 - 12:23 AM
its in.....
#29 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 20 August 2017 - 07:14 AM
You're going to need spoilers to keep this thing on the road....
Posted Image
#30 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 12,717 posts
  • Cars:1971 2 door 510, 1969 4 door 510, 2002 Tacoma double cab
Posted 20 August 2017 - 07:16 AM
Looks great!!
View my 69 510 4dr Sedan - Build Thread
View my 71 510 2dr Sedan - Coming soon.
http://drakers.pl510.info
#31 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 20 August 2017 - 09:05 AM
Looks great!!
Thanks.
Considering I totalled my dual cam KA swapped A10..... I learned my lesson. NO cut springs this time and MUST have proper brakes and tire setup (unlike my A10)
#32 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 20 August 2017 - 09:07 AM
The only thing I'm concerned about is the rear end blowing up. Still has the little H150. Considering going Ford 8".
#33 Sastis
Sastis
    Advanced Member
  • Members
  • PipPipPip
  • 171 posts
  • Cars:78 620 KC, 70 Datsun 510 2dr
Posted 20 August 2017 - 04:33 PM
If you ever decide to go ka, I like to buy the lz engine from you.
#34 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 20 August 2017 - 04:54 PM
Thanks, but I've had a half of dozen KAs... Not sure I'll ever go back
#35 Sastis
Sastis
    Advanced Member
  • Members
  • PipPipPip
  • 171 posts
Posted 20 August 2017 - 05:04 PM
if you go a different route. I call dips. PS. There is another 4dr b210 for sell in SeaTac if you ever want another one.
#36 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 20 August 2017 - 05:44 PM
 link to ad?
#37 datsunfreak
datsunfreak
  • Senior Member
  • 13,317 posts
  • Cars:'73 1200 Coupe, '77 280Z
Posted 22 August 2017 - 05:44 PM
It'll handle just about anything a non-turbo L can throw at it.
It's your car, just don't ruin it.
It's also not my money, so i'll suggest the most expensive option.
#38 datsunfreak
datsunfreak
  • Senior Member
  • 13,317 posts
Posted 22 August 2017 - 05:46 PM
Also, 68-72 510 wagon H190 is bulletproof and a super easy swap.  :thumbup:
#39 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,001 posts
Posted 22 August 2017 - 08:00 PM
Thanks!
