Datsun B210 - LZ23, 5 spd. The Definitive B210 swap thread.
  • Please log in to reply
59 replies to this topic
#41 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
  • Cars:'93 240SX, '78 620, '76 B210, '65 320
Posted 27 January 2018 - 11:04 AM
#42 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 27 January 2018 - 11:09 AM
I have these same wheels, but they're not finished like this. I want to make mine look similar.
I traded off my Hayashi Commands for a Z22 core engine for a future build.
More to come............................
#43 datsunfreak
datsunfreak
  • Senior Member
  • 13,767 posts
  • Cars:'73 1200 Coupe, '77 280Z
Posted 27 January 2018 - 12:29 PM
A few addenda if I may...
 PL510 (1968-'72) crossmember DOES bolt into a B210 without issue, I also used B210 lower control arms w/ the 510 xmember. This works and has no issues.
Using the 510 crossmember wih B210 control arms will widen your track slightly and add some negative camber (not necessarily a bad thing). Using 510 control arms fixes this issue and they bolt right in also.
Datsun drivelines have staked ujoints and are typically not serviceable. I chose to have a custom driveline made with serviceable ujoints.
There are several Datsuns that do not use staked in joints. The 510, 610, 620, 240Z, 260Z, and 280Z use replaceable joints. The Zs would obviously be too short for a donor unless you plan to retube it, but the 510 and 620 could be used if cut down slightly and used with a long tail 5 speed.
A good rule of thumb seems to be if it had an L-series, it had replaceable joints. If it had an A-series, it had staked in joints. I can't speak to whether the A10 or 710 used replaceable joints however.
- Swap ignition to driver side and remove points setup if so equipped.
One can also run a longer coil wire and loom it in with the spark plugs wires as an alternative.
It's your car, just don't ruin it.
This seems like an elaborate ploy to get me to say "I like the D".
#44 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,219 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 27 January 2018 - 02:03 PM
The 710s are replaceable.
I had a '76 B-210 new and the U joint failed... got one from a wrecking yard.
Some old chevs injected plastic to fix the U joint in place, but you could knock them out and the replacements had C clips and the yokes were grooved to accept them.
Posted Image
#45 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 27 January 2018 - 03:33 PM
I got an A10 driveline. It had staked joints.
I chose and A10 due to being L series and H165. Both the yoke and flange were compatible for my application.
#46 bananahamuck
bananahamuck
    S&S chicken/rice
  • Senior Member
  • 13,582 posts
  • Cars:Cleopatra does the nasty.
Posted 27 January 2018 - 05:29 PM
How much you want for the bumpers ?
So somehow while i was driving back from Eaglerock swap meet i somehow caused YOU to post this,,,, do really think members on this site are that stupid to believe i caused it??
http://community.rat...un-for-a-while/
Yeah i guess you do,,
BTW ,,,, the first person to call you a pussy,,,, ya might wanna check out his ethnicity ,, cuz i don't think it's what you think it is there snowflakeboy
..........................I shall call it, narclops.
#47 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 27 January 2018 - 07:01 PM
I'm in them $350
....or you talking about the stock USDM bumpers?
#48 dat521gatherer
dat521gatherer
  • Senior Member
  • PipPipPipPipPip
  • 2,489 posts
  • Cars:3 521's 75 b210 80 supra 80 audi 4000 80 b310
Posted 27 January 2018 - 08:34 PM
I'm enjoying watching this build but I think I'll stick with the A series. I can't wait to see this at a meet. Or the 320.
Where did you get that valve cover?
#49 datzenmike
datzenmike
    KING RAT
  • 72,219 posts
Posted 27 January 2018 - 08:41 PM
I need a ride in this.
Posted Image
#50 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 27 January 2018 - 08:58 PM
Dat521....
Thanks for recognizing the valve cover. It Stokes my ego haha. It's exclusive to South AfricA(?). I had it imported and I got it powdered coated locally here in WA. Not to be a brag, but it was very expensive! I don't regret it. Haha.
And Mike, I will gladly let you drive it at Canby!
#51 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 27 January 2018 - 08:59 PM
At times, I wish I would have left the A14 in it just so I could drive the damn thing....
#52 datzenmike
datzenmike
    KING RAT
  • 72,219 posts
Posted 27 January 2018 - 09:14 PM
Hell a ride would be good enough. You can show me what it can do.
Posted Image
#53 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 28 January 2018 - 05:26 PM
Only thing I'm worried about is the rear end blowing up.
#54 Dguy210
Dguy210
    Service Manual Technician
  • Senior Member
  • PipPipPipPipPip
  • 2,765 posts
  • Cars:'74 4dr B210, '71 1200 (KA24E swap project)
Posted 28 January 2018 - 05:44 PM
I put the 510 wagon rearend (H190) in my 1200 sedan KA swap. Pretty much bolt-in, should fit the B210 pretty well.
#55 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Thanks for the tip.
#56 datsunfreak
datsunfreak
  • Senior Member
  • 13,767 posts
Posted 29 January 2018 - 03:02 PM
Thanks for the tip.
FYI, it's roughly 2" wider, but is basically a bolt-in affair as he said.
http://community.rat...310-and-others/
I have used (and abused) B210 rear ends with engines this strong or stronger in 1200s with no fuss. I do have a minor concern that in the heavier B210 your experience may vary.
#57 datzenmike
datzenmike
    KING RAT
  • 72,219 posts
Posted 29 January 2018 - 06:29 PM
Don't forget the tire acts like a fuse.
Posted Image
#58 bananahamuck
bananahamuck
    S&S chicken/rice
  • Senior Member
  • 13,582 posts
Posted 29 January 2018 - 09:47 PM
I'm in them $350
  Bullshit i see the fiberglass ones on Craigslist all the time for like $150. bucks ,, and they don't rust and bend..
I will give you $75. dollars and you deliver
#59 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 29 January 2018 - 10:27 PM
Swear dude. Got them from Mike Currier in Yakima for $350.
#60 mhub91
mhub91
    M&M
  • Senior Member
  • PipPipPipPipPip
  • 2,057 posts
Posted 15 February 2018 - 09:08 PM
Not much news lately. Missing my 320 and really want to drive that.
