720inOlyWa Posted March 27, 2017 Report Share Posted March 27, 2017 I have both Z24 head versions and both are fresh and ready to go into my most recent acquisition, should one be required. But this new truck is an 84, and I won‘t know which version it is until I remove the intake manifold, I reckon. Does anyone know when they switched over from round to squarish? Most that I see are the squarish intake port heads. In fact, I mistakenly used a round intake port on a squarish intake port head and it seemed to run fine for 15k miles. So I also wonder if it makes a difference at all if you interchange them. anyone know? 1 Quote Link to comment
datzenmike Posted March 27, 2017 Report Share Posted March 27, 2017 Changed when the Z24 came out October '82 or a few months into the '84 model year to replace the Z22. It's strictly found only on the Z24 although the head and the intake will work just as well on a Z20 or Z22. You can interchange the round and square port intakes but.... Top is one of my Z24 heads. Below is a Z20/Z22 head. 2 Quote Link to comment
720inOlyWa Posted March 27, 2017 Author Report Share Posted March 27, 2017 Changed when the Z24 came out October '82 or a few months into the '84 model year to replace the Z22. It's strictly found only on the Z24 although the head and the intake will work just as well on a Z20 or Z22. You can interchange the round and square port intakes but.... Top is one of my Z24 heads. Below is a Z20/Z22 head. But what? It aint right? 1 Quote Link to comment
datzenmike Posted March 27, 2017 Report Share Posted March 27, 2017 Z24 heads only have square intakes. A Z24 head can be identified by the fuel pump opening not being machined out. Just like the top head in my picture. It's possible that someone may have swapped a Z22 head on but if a Z24 head it will have square intake ports and should have a square intake to match. 2 Quote Link to comment
720inOlyWa Posted March 27, 2017 Author Report Share Posted March 27, 2017 Got it. Thanks! This clarifies the picture on the service history of the poor old Fudgecicle. The Z22 head, was only one of the shakey bits that I have come across. The drivetrain was really cobbled together out of shite. Now it is all replaced / rebuilt. Does anyone have any use for a relatively fresh Z22 head?.... Quote Link to comment
720inOlyWa Posted March 31, 2017 Author Report Share Posted March 31, 2017 Well, I am in luck, I guess. I hooked up the garden hose to the concrete sink in the garage and did some hot water cleaning under the hood of this new acquisition and discovered it has a Z20 engine. That means my fresh-is Z22 head I have laying around will work nicely. The engine itself had a bead of silicone laid in around the rubber gasket on the valve cover, suggesting a futile attempt to stop oil leaks around the cover. The cleanup suggested that oil was seeping from the cover for a while. I take this to suggest that perhaps the valve guides are worn and were pumping oil up top, so swapping out the head and performing a preemptive head gasket replacement should go a ways towards pleasant driving. It will also give me a chance to inspect the cylinders themselves. Quote Link to comment
