CableDroid Posted March 25, 2017 Report Share Posted March 25, 2017 Hey guys, did a 280zx front brake swap on my 510. New pads, new brake hoses, new 280z 7/8" master cylinder... The rear brakes bled easy. The front is another story. I will get air bubbles from the passenger front caliper bleeder a couple of times, then it's good. Same with the driver side. But the 1st push of the pedal is soft, but the immediate second pump is firm. Wait a second and the first pump is soft again. If I go back to the passenger front caliper....air again. Same with the driver side. I can literally go side to side and get air, then nothing. Checked all connections at least a dozen times, even put a white towel under the car and not a drop. All connections are dry as a popcorn fart. Quote Link to comment
datzenmike Posted March 25, 2017 Report Share Posted March 25, 2017 Did you bench bleed the master? Are the struts swapped L for R? Are the calipers to the front of the wheels or to the rear like the calipers they replace? 1 Quote Link to comment
CableDroid Posted March 25, 2017 Author Report Share Posted March 25, 2017 Bench bled several times, no air after the first time. Swapped side to side, bleeder screws on the top. Quote Link to comment
Doctor510 Posted March 25, 2017 Report Share Posted March 25, 2017 Bench bled several times, no air after the first time. Swapped side to side, bleeder screws on the top. Bleed the M/C again in the car Quote Link to comment
CableDroid Posted March 25, 2017 Author Report Share Posted March 25, 2017 Already did that, twice. No air. Quote Link to comment
datzenmike Posted March 25, 2017 Report Share Posted March 25, 2017 I guess you could remove the caliper with brake line attached, place a chunk of plywood between the pads to simulate the rotor, turn them up so you are sure all the trapped air is to the top where the bleeder is and try again. Quote Link to comment
banzai510(hainz) Posted March 25, 2017 Report Share Posted March 25, 2017 I stuck my finger inside the master and plugged the hole and had someone push the brakes to get better suckction/pushing I always buy new not the rebuild cardone remans one with no resivior. Quote Link to comment
