Turn Signal/Flasher Shuts Off Headlights 73 240Z
Hung
Here's one for the electrical experts...when I use my left turn signal it completely shuts off my headlights.  When this happens, if I switch the headlights to the parking light or off positions the headlights turn back on.  I've noticed the when if I use the right turn signal the headlights will come back on.  I also have to lift up harder in order for my right turn signal to work.
At first I thought the headlight relays were bad but I diagnosed this last night after a drive.  Electrical is not my strong suit so any help would be appreciated!
A little background on the car: 1973 240Z with an L28 5 speed from a 280Z, the PO installed headlight relays on the vehicle.
  • Replies 5
when he installed the relays ,Is it a H4 harnnes type set up. (prefab) or soemthing the prev owner made up (lots of loose wires)
If a harnees. then just disconnecte it and hook back up to stock and see what happens.
If what he made then Your on your own.
I would just disconnect the lamps and try again and see what happens with the signals.
the lamp circut should be separate from the other stuff.
