L18 bottom thermostat housing
racerx
  • Replies 3
IIRC, '79 and up (4 cylinder at least) have the three bolt top thermostat cover. Later EFI Z car and 810/Maxima housings had up to three temp sensors plus the gauge sender plus the ERG thermal vacuum valve. All will work if that's all you can find.
