KoHeartsGPA Posted May 22, 2017 Author Report Share Posted May 22, 2017 Bunch of work done this weekend..... Had a friend finish up my roof during the week, he's a body shop guy and needed a windshield, so we helped each other out, basically all this roof needs now is primer, that will get done this week... I cleaned up the rust and sprayed rust treatment on my passenger side fender, wasn't nearly as bad as the driver side... Used a metal mesh as a base for the duraglas... Applied duraglas... While that cures for couple days I started on the floor panels, the most severely damaged by rust was the passenger side... Few holes revealed after running a wire brush to it, so I decided to use fiberglass sheets on it, I coated the floor panel with POR15 and layer the fiberglass sheets on top then applied a wet coat of POR15... Then I proceeded with the rest of the floor, no more rust damage was revealed... Very minimal surface rust that was brushed and cleaned up... Finished application of POR15... Turned out nicely... Can't wait for next weekend so I can get more work done!! 2 Quote Link to comment
KoHeartsGPA Posted June 1, 2017 Author Report Share Posted June 1, 2017 More work done this past weekend... Sanded down the duraglas, applied filler and sanded down to blend in with the body line of the passenger side fender, just needs glaze putty and a final sand before primer... Finished the interior side of welding filling, nice and smooth straight across now, ready for primer... Started the process of filling and blocking the exterior side of the cab to accomplish a smooth straight line across... Worked it from the middle and outward to the sides in order to get an even line... Lots of filling and blocking, piles of dust on the floor, but successfully sculpturing the body line... Halfway there now... While the filler dried for sanding, I tackled other parts needing blocking... Smooth and even now... Also picked up a donor to use the chassis off of, has a bad transmission, but I already have a KA and tranny... Can't wait for next weekend! 4 Quote Link to comment
Draker Posted June 1, 2017 Report Share Posted June 1, 2017 620 on a 720 frame huh? Sweet! 2 Quote Link to comment
KoHeartsGPA Posted June 5, 2017 Author Report Share Posted June 5, 2017 Several more hours of work today, not many pictures since most of the day was spent making filler dust..... Getting close to finishing up the back of the cab now... Don't have after pics, finished the passenger side fender too, needs glaze putty for the pin holes. While filler was drying, I tackled the rusted out of hope battery tray and surrounding victim... Started cutting away the damaged area... Off it came... Nice clean hole now... Sprayed rust treatment around the area to eliminate some surface rust... Next weekend I'll be wrapping up the body work on the cab and start doing some work on the bed... I do have a wheel preview... Can't wait to finish this thing! 3 Quote Link to comment
Draker Posted June 5, 2017 Report Share Posted June 5, 2017 Man I wish I could come hang with you guys on the weekend. Only problem is I'm doing the same shit all day, 15 miles north. I'll make it over in a few weeks. Next two weekends I'm booked. 1 Quote Link to comment
KoHeartsGPA Posted June 5, 2017 Author Report Share Posted June 5, 2017 I know the feeling, Craig, I've been itching to visit your operation and I just cannot find the time, my goal is to have this thing running by the time July rolls in :frantics: 2 Quote Link to comment
KoHeartsGPA Posted June 11, 2017 Author Report Share Posted June 11, 2017 Did more work on DatLo yesterday and today, cleaned up the engine bay and inside the wheel wells for paint and undercoating, lots of time went into prep so I was only able to paint the engine bay today, tomorrow I'll do the rubberized undercoating in the wheel wells, back of fenders and under side of the bed. Here's pics of the engine bay using a textured paint I'm experimenting with... After... Can't wait to see it tomorrow after it cured for 12+ hours, I really like the finish where it stands, let's see how it looks after its cured. 2 Quote Link to comment
Ratwagon1600 Posted June 11, 2017 Report Share Posted June 11, 2017 Did more work on DatLo yesterday and today, cleaned up the engine bay and inside the wheel wells for paint and undercoating, lots of time went into prep so I was only able to paint the engine bay today, tomorrow I'll do the rubberized undercoating in the wheel wells, back of fenders and under side of the bed. Here's pics of the engine bay using a textured paint I'm experimenting with... After... Can't wait to see it tomorrow after it cured for 12+ hours, I really like the finish where it stands, let's see how it looks after its cured. Your just posting this to shame me into doing stuff on my 720 ;) 3 Quote Link to comment
Draker Posted June 11, 2017 Report Share Posted June 11, 2017 Looks good man! Keep it up. 3 Quote Link to comment
KoHeartsGPA Posted June 12, 2017 Author Report Share Posted June 12, 2017 Sprayed two more coats of paint in the engine bay today... Satisfied with the finish in the engine bay I sprayed rubberized undercoating in the wheel wells and fenders... Next weekend I'll finish cleaning up the under side of the bed and spray it with rubberized undercoating. 1 Quote Link to comment
HOGIE Posted July 2, 2017 Report Share Posted July 2, 2017 Too much work getting done to post updates? 2 Quote Link to comment
KoHeartsGPA Posted July 5, 2017 Author Report Share Posted July 5, 2017 Ya, plus photoFUCKIT is.....well....fucked up now....no sense in posting any updates with no oics. 1 Quote Link to comment
Charlie69 Posted July 5, 2017 Report Share Posted July 5, 2017 Post the updates and keep taking pictures of the progress please. You will figure it out. Please do not let PhotoFuckit dictate your posting here on Ratsun. This will not help you Ratsun or us in this mess. Rise above it and keep moving forward. 2 Quote Link to comment
]2eDeYe Posted July 5, 2017 Report Share Posted July 5, 2017 Just switch over to imjur and keep updating :) 2 Quote Link to comment
KoHeartsGPA Posted July 5, 2017 Author Report Share Posted July 5, 2017 Post the updates and keep taking pictures of the progress please. You will figure it out. Please do not let PhotoFuckit dictate your posting here on Ratsun. This will not help you Ratsun or us in this mess. Rise above it and keep moving forward. Oh ya, my phone is with me at all times documenting my progress by snapping oics, got the motor freshened up yesterday, the timing chain and guides are new, got a 2wd pan on there, new water pump, gaskets and just needs the new flywheel + clutch installed, attach the tranny and drop it in the chassis, got a full 12 hours on her yesterday alone....lots of work this past weekend for sure! Just switch over to imjur and keep updating :) Thank you Steve, I'll look into that ;) 2 Quote Link to comment
Charlie69 Posted July 5, 2017 Report Share Posted July 5, 2017 Here I can't spell either Redeye! LOL http://imgur.com/ 2 Quote Link to comment
Crashtd420 Posted July 5, 2017 Report Share Posted July 5, 2017 If your having issues posting with imgur or flicker from your phone try postimage... works very easy from the phone.... no app but I was able to put a quick link icon up on my phone.... Use the forum hot link ... nice and easy... 4 Quote Link to comment
