KoHeartsGPA Posted March 26, 2017 Author Report Share Posted March 26, 2017 Hidden in plain sight ;) 1 Quote Link to comment
HOGIE Posted March 26, 2017 Report Share Posted March 26, 2017 Hidden in plain sight ;) Your a sneaky bugger aren't you? 1 Quote Link to comment
KoHeartsGPA Posted April 2, 2017 Author Report Share Posted April 2, 2017 More mudding happened yesterday.... Can't wait to finish the roof, ugh! Patched couple holes with duraglas and finished off with bondo... The front of the roof is at about 90% at achieving the correct line, once that has happened I can follow it to the back of the cab with a thin coat covering the rest of the low spots that were created by the welding of the roof, lots of work but she's taking shape now. 4 Quote Link to comment
2wheel-lee Posted April 3, 2017 Report Share Posted April 3, 2017 Coming to Southern California soon? Now that you have practice with roof work, I'd welcome you to come and do mine. ;) 1 Quote Link to comment
KoHeartsGPA Posted April 3, 2017 Author Report Share Posted April 3, 2017 Coming to Southern California soon? Now that you have practice with roof work, I'd welcome you to come and do mine. ;) LOL yours can't possibly be worse than this one was, unless its smashed in? Quote Link to comment
Draker Posted April 3, 2017 Report Share Posted April 3, 2017 Are your arms burning still? (From all that sanding) 1 Quote Link to comment
KoHeartsGPA Posted April 3, 2017 Author Report Share Posted April 3, 2017 Are your arms burning still? (From all that sanding) Lil bit.,.. But can't blame it on sanding, niece birthday yesterday and few hours of picking up my two nephews, throwing them on my shoulders and running from my niece that was trying to save them :thumbup: 2 Quote Link to comment
]2eDeYe Posted April 3, 2017 Report Share Posted April 3, 2017 Hope that sticker makes it onto the truck :D 1 Quote Link to comment
KoHeartsGPA Posted April 3, 2017 Author Report Share Posted April 3, 2017 Hope that sticker makes it onto the truck :DNot quite... But I will be ordering couple more items from you since I've decided to go E instead of carburated..... 2 Quote Link to comment
KoHeartsGPA Posted April 23, 2017 Author Report Share Posted April 23, 2017 Been working on her last few weeks, just haven't posted pics.... Catching up now.. Body filler on the tacks I made in and out the cab.... Last of the body filler on the roof, next step will be glaze putty... Today I fixed a bad rust spot on my driver side fender, cleaned it up..... Cut out another piece of metal to fit behind the damaged area.... Tack welded it in place, did some filling with the welder, grinded it down to make it flush to the body line... Mixed some duraglas for body filling.... Added extra hardener so it would take effect quicker so I can sand it down sooner and within 30 minutes it was ready for sanding, turned out good.... Monday I don't have to go to work so I'll be working on her again applying glaze putty :thumbup: 2 Quote Link to comment
Draker Posted April 23, 2017 Report Share Posted April 23, 2017 That cleaned up nicely! 2 Quote Link to comment
KoHeartsGPA Posted April 23, 2017 Author Report Share Posted April 23, 2017 Thanks!, Ya I wasn't sure if I could save it, worst case scenario was cutting out the part and weld another that wasn't damaged, but seems as most fenders that old have the same rust damage, some worse than others, passenger side fender looks ok though, just surface rust :thumbup: 1 Quote Link to comment
Draker Posted April 23, 2017 Report Share Posted April 23, 2017 Owners need to hose the dirt out from back there. Otherwise rust! 3 Quote Link to comment
KoHeartsGPA Posted April 23, 2017 Author Report Share Posted April 23, 2017 Ya, I'm going to do what I did with my dime, spray that rubberized bed liner inside the fenders and under the body & Bed of the truck. 2 Quote Link to comment
KoHeartsGPA Posted April 25, 2017 Author Report Share Posted April 25, 2017 More work done on DatLo... Removed the rocker panel that was rusted out of hope and cleaned up the area for the new piece.... Sprayed rust treatment... Let it dry then ran the wheel brush and sprayed rust treatment again... Also applied more body filler to back side of the cab over the tac welds.... 3 Quote Link to comment
Charlie69 Posted April 25, 2017 Report Share Posted April 25, 2017 Looking like you are doing a thurough job. Keep at it and it will be done sooner than you think. 1 Quote Link to comment
KoHeartsGPA Posted April 25, 2017 Author Report Share Posted April 25, 2017 Thank you, Charlie!, Ya my goal is to have her running by July, she's gonna be my daily once done ;) 1 Quote Link to comment
KoHeartsGPA Posted April 30, 2017 Author Report Share Posted April 30, 2017 More work got done yesterday.... Removed the rocker panel from a donor 620, that was a job in it of itself..... Cut off all excess metal and cleaned up the piece that will go in.... Drilled holes for the tac welds...... Test fit for final prepping... Next time I'll finish this chapter of DatLo. This morning before heading back to the road, I found this nice surprise in my mailbox, more 620 parts! Ordered these over a month ago :) 4 Quote Link to comment
Jersey Posted May 4, 2017 Report Share Posted May 4, 2017 Looking good my friend! 2 Quote Link to comment
KoHeartsGPA Posted May 4, 2017 Author Report Share Posted May 4, 2017 Thank you, Jersey, I'm having a blast doing it, can't wait to finish and start my GF's goon build! 2 Quote Link to comment
KoHeartsGPA Posted May 14, 2017 Author Report Share Posted May 14, 2017 Did more work on DatLo today... Prepped and tac welded the rocker panel. Cleaned up the welds and applied duraglas. Tomorrow I'll sand and add body filler as needed. 2 Quote Link to comment
Charlie69 Posted May 14, 2017 Report Share Posted May 14, 2017 One peice at a time and one less piece to repair. Nice work KoHeartsGPA! 1 Quote Link to comment
hobospyder Posted May 14, 2017 Report Share Posted May 14, 2017 dude, crossmember goes under the car not in it 3 Quote Link to comment
KoHeartsGPA Posted May 15, 2017 Author Report Share Posted May 15, 2017 Did more work today, pretty much finished the rocker panel, just needs glaze putty and little bit of sanding and it's done... Did more filling and blocking on the roof... Taking shape, now I gotta follow the lines, lots and lots of blocking lol 1 Quote Link to comment
