300zx wheels
  • Please log in to reply
8 replies to this topic
#1 edekalil
edekalil
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,053 posts
  • Cars:3-510 2 door sedans, 2 wagons all early 70s
Posted 04 March 2017 - 02:42 PM
I know I have asked about these wheels befor, they do fit on the rear on a stock 510 with a spacer I got from Foto Fab can't remember the spacing or thickness. I know you have to use a thicker spacer and longer studs to run them on the front with 280zx struts. What I need to know is if using a shortend stock strut on a 510 how thick of a spacer do you need and do you still need the longer studs? Any info would help.
CEO of the McComb, MS chapter of the 510
#2 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,584 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '05 Saabaru 92x, '07 Saab Trollblazer 97x
Posted 04 March 2017 - 03:53 PM
Just to help anyone who can assist here, those rims are
15x6.5 et+30
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#3 edekalil
edekalil
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,053 posts
Posted 04 March 2017 - 04:06 PM
15x6.5 et+30
Thank you I should have added this.
#4 edekalil
edekalil
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,053 posts
Posted 04 March 2017 - 04:09 PM
I'm thinking of using them on the Goon.
Because I have had them with new tires for a while sitting inside the whole time not in the sun and figured why not befor they go bad. Trying to save a few dollars to get new tires on the 70 sedan.
#5 Ranman72
Ranman72
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 5,886 posts
  • Cars:68 datsun 510 2 door / 69 Datsun Roadster /05 350z / 08 f350 / 73 datsun 1200 coupe
Posted 07 March 2017 - 05:29 PM
I have ran these before and used a 10mm spacer with zx struts if i remember correctly
on the rear i didnt need a spacer but i had to use sticky weights on the inside lip or it would hit the a arm  it was that close
if you are running a coil over set up your spacer might have to be bigger because of the weld on perch
this was all with 195 50 15 tires
#6 edekalil
edekalil
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,053 posts
Posted 14 March 2017 - 08:03 AM
Thanks for the info. I have some 280zx struts but plan to use them on a sedan I have. Gonna try to use on some shortened stock struts.
#7 Ranman72
Ranman72
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 5,886 posts
Posted 14 March 2017 - 08:14 PM
on stock struts not shortened i had about 1 to 2 mm of space and in cornering they would rub so slightly that there was no tire wear but a shiny spot on the strut
#8 edekalil
edekalil
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,053 posts
Posted 19 March 2017 - 06:14 AM
Thank you again, I do have some 3/8 in spacers that worked on back good I'll look today how the front looks on a stock strut as is. I'm not sure if the spring purchase will be a problem but I'll find out. I really need to save some money and use these since the tires are good and I have to get a set for a couple of the other cars. That's what I get for buying stuff before I'm ready to use it.
#9 edekalil
edekalil
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,053 posts
Posted 22 March 2017 - 06:04 PM
Well here are the wheels on the car now.
Seems to clear everything.
It would probably work with shortened struts and coilovers not the stock style shorter springs and perch.
Boy I realy need to do some frontend work on this car.
