Draker Posted July 6, 2020 Report Share Posted July 6, 2020 11 minutes ago, captain720 said: I got the alternator business all figured out, lets just say everything that could be wrong with a charging system went wrong all at once. I don't like photo hosting sites anymore so I just make You Tube videos. https://www.youtube.com/watch?v=S4dUwdfaxKw You can upload directly to the forum now. Cud’s are good too.. but better if embedded. 1 Quote Link to comment
captain720 Posted July 6, 2020 Author Report Share Posted July 6, 2020 16 minutes ago, Draker said: You can upload directly to the forum now. Cud’s are good too.. but better if embedded. Video embed feature is not working for me unfortunately. 2 Quote Link to comment
Draker Posted July 6, 2020 Report Share Posted July 6, 2020 1 hour ago, captain720 said: Video embed feature is not working for me unfortunately. try patching your kernel. (Linux jab) 🤓 2 1 Quote Link to comment
captain720 Posted July 9, 2020 Author Report Share Posted July 9, 2020 I am going to try the Instagram photo hosting here goes. I got a new solonoid to replace the Chevy truck one I used to actuate my fender fuse block because that one melted. 2 Quote Link to comment
bottomwatcher Posted July 21, 2020 Report Share Posted July 21, 2020 Gatorade bottle is ratsunesque, most folks use cheap aluminum beer bottles (Coors screw top) but the clear plastic makes sense. The solenoid for the fuse panel doesn't make sense to me unless there are circuits that have a constant drain. A fuse that is below the rating of the supply wire should be located as close to the battery as possible. Keep it simple and safe. 3 Quote Link to comment
captain720 Posted July 21, 2020 Author Report Share Posted July 21, 2020 3 hours ago, bottomwatcher said: Gatorade bottle is ratsunesque, most folks use cheap aluminum beer bottles (Coors screw top) but the clear plastic makes sense. The solenoid for the fuse panel doesn't make sense to me unless there are circuits that have a constant drain. A fuse that is below the rating of the supply wire should be located as close to the battery as possible. Keep it simple and safe. The solonoid turns the alternator and the choke heater on and off. both are a continuous drain if left unchecked and all the wires are larger than the fuse size. Everything overdone and safe. Factory wiring on a truck like this gets to a hopeless point and you just have to start making things work anyways. A water damaged fuse block is a nightmare. 3 Quote Link to comment
Charlie69 Posted July 22, 2020 Report Share Posted July 22, 2020 Instagram hosting sucks after the first 24 hours then I have to click on the link to see the picture. 1 Quote Link to comment
captain720 Posted July 22, 2020 Author Report Share Posted July 22, 2020 9 hours ago, Charlie69 said: Instagram hosting sucks after the first 24 hours then I have to click on the link to see the picture. That's terrible, thanks for letting me know. It still shows embedded to me but it's my photo so that could be why 1 Quote Link to comment
Draker Posted July 22, 2020 Report Share Posted July 22, 2020 5 hours ago, captain720 said: That's terrible, thanks for letting me know. It still shows embedded to me but it's my photo so that could be why I can see it just fine. 2 Quote Link to comment
Charlie69 Posted July 24, 2020 Report Share Posted July 24, 2020 On 7/20/2020 at 7:04 AM, captain720 said: This is what I see now. Quote Link to comment
captain720 Posted August 1, 2020 Author Report Share Posted August 1, 2020 I'm working on my body panel welding, I got better as I went along but I know it's rough. Better than rust at least. 1 Quote Link to comment
Charlie69 Posted August 1, 2020 Report Share Posted August 1, 2020 You should have grabbed replacement doors and fenders from me when you were here. I try to keep a couple sets on hand just in case one of the snowbirds, blue hairs get in my way! LOL 1 Quote Link to comment
captain720 Posted August 1, 2020 Author Report Share Posted August 1, 2020 Thanks Charlie! I actually have a spare set of doors or two, I just really like to take what I have and make what I need and this rig sees a lot of trail use so rattle can patch panel is just the way it is 1 Quote Link to comment
captain720 Posted August 1, 2020 Author Report Share Posted August 1, 2020 I don't want to put a brand new door on just to have a tree branch take it out if ya know what I mean. 1 Quote Link to comment
Charlie69 Posted August 2, 2020 Report Share Posted August 2, 2020 I know what you mean. I thought that was the truck you were fixing up to daily drive. 1 Quote Link to comment
captain720 Posted August 7, 2020 Author Report Share Posted August 7, 2020 I got some used alluminum wheels at the wrecking yard for $35 out of a beat up pathgrinder. They work, seems to have less backspacing than the factory ones though. 1 Quote Link to comment
captain720 Posted August 10, 2020 Author Report Share Posted August 10, 2020 Tailgate got squished today (third photo in) so I may need to go flatbed this winter. Oh well just like the door I don't plan on putting a good one on as it would meet the same fate. 2 Quote Link to comment
captain720 Posted June 4, 2021 Author Report Share Posted June 4, 2021 The Bearing on my power steering tensioner pulley got so bad the pulley actually flexed so far it would spark against the mount bracket when I tightened it up. I was able to find a napa pulley with the right size bearing and the machine shop pressed in my bushing for almost free. 2 Quote Link to comment
captain720 Posted June 28, 2021 Author Report Share Posted June 28, 2021 Water pump got so bad that the impeller was moving around taking little pieces out of the timing cover, check out the video for more details and a better look at just how bad that bearing got. https://youtu.be/YuOpQPY1s1A 2 Quote Link to comment
NC85ST Posted June 28, 2021 Report Share Posted June 28, 2021 Years ago, I had one fly apart on me. Sent the fan into the radiator about 1 1/2 miles from home. Good thing you caught it quick enough, mine wasn’t making a noise for long before it went. Looks like you might have a valve cover gasket issue as well. 1 Quote Link to comment
captain720 Posted June 29, 2021 Author Report Share Posted June 29, 2021 5 hours ago, NC85ST said: Years ago, I had one fly apart on me. Sent the fan into the radiator about 1 1/2 miles from home. Good thing you caught it quick enough, mine wasn’t making a noise for long before it went. Looks like you might have a valve cover gasket issue as well. Yeah I knew I did not have long before that would have happened 2 Quote Link to comment
captain720 Posted July 6, 2021 Author Report Share Posted July 6, 2021 Replaced the electric choke with a new one, really made a difference. The old one just plain got old and was opening too fast, I think the Weber has been on the truck for at least 150k. Here's a link to the video, I am now just doing videos instead of posting pictures of my stuff. 1 Quote Link to comment
captain720 Posted July 13, 2021 Author Report Share Posted July 13, 2021 Got my valve cover replaced today and had to do the brake booster vacuum line as well. Recorded a video but probably not going to get it edited for a little while 1 Quote Link to comment
captain720 Posted July 17, 2021 Author Report Share Posted July 17, 2021 Video on the valve cover gasket/brake booster replacement is done if anybody is interested or if maybe it could help somebody out. 1 Quote Link to comment
