captain720 Posted February 24, 2017 Author Report Share Posted February 24, 2017 It is a 32/36, thanks DrvnDrvr. Quote Link to comment
captain720 Posted February 24, 2017 Author Report Share Posted February 24, 2017 Also when I took the vacuum line off I could feel a massive vacuum at idle so I think the brass nipple is just plug able. The brass does not seem to have a vacuum at all when I put my finger over it and rev it up. 1 Quote Link to comment
captain720 Posted February 24, 2017 Author Report Share Posted February 24, 2017 Does anyone have some fender mounted turn signals they are willing to sell? 1 Quote Link to comment
captain720 Posted February 25, 2017 Author Report Share Posted February 25, 2017 I got some from the wrecking yard just now, along with a mud flap for the driver side. 1 Quote Link to comment
captain720 Posted February 25, 2017 Author Report Share Posted February 25, 2017 I have been keeping my eyes open for a good parts/donor truck for cheap because I find myself going junkyard hunting regularly, what years would make good parts trucks for my 1984 engine 1986/85 truck combination? Is an 83 too old? There a few early eighties Datsun 720s around and a couple Nissan 720s around with descent bodies and blown motors. Plus a ton of them on the West side of the mountains. What year would be best? Thanks Quote Link to comment
DrvnDrvr Posted February 25, 2017 Report Share Posted February 25, 2017 Most likely an 83+. but it depends on what you need to get where you want it to be. Since you don't have to smog,keep the engine as simple as possible Make a list of parts to get it there. Research http://720world.com/ http://forums.nicoclub.com/datsun-720-forum.html http://www.ebay.com/sch/i.html?_odkw=83+nissan+720+parts&_sop=10&LH_ItemCondition=4&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.A0.H0.Xnissan+720+parts.TRS1&_nkw=nissan+720+parts&_sacat=0 http://community.ratsun.net/forum/53-720/ https://www.nissanpartsdeal.com/1983-nissan-720-pickup-parts.html?Filter=(1=K%2fCAB;2=Z24;3=DX;4=F5;5=LONG;6=4WD;7=FED) https://www.rockauto.com/en/catalog/nissan,1983,720+pickup,2.4l+l4,1210295,drivetrain http://www.partsgeek.com/ymm/1983/nissan/720.html Be great if you found a cherry 83-5 720 with a bent frame. checkout http://www.redlineweber.comon how to tune your carb Quote Link to comment
captain720 Posted February 26, 2017 Author Report Share Posted February 26, 2017 Thanks, I will look into getting one of those tuning kits. What would cause my headlights to be very dim? I just had my alternator checked at a local shop that does it for free and it was fine. Or are they just very dim on these trucks? Also what kind of stuff should I put on connections when I clean them? And my oil pressure sensor is very slow to respond, what should I check for that? Quote Link to comment
Lockleaf Posted February 27, 2017 Report Share Posted February 27, 2017 Halogen headlights dim over time. It may just be that. You can also check for voltage at the headlight connections. See if it's much lower than battery/alternator voltage. Oil pressure gauges in these are typically slow to respond. Its normal. Does the light turn off quickly? 1 Quote Link to comment
captain720 Posted February 28, 2017 Author Report Share Posted February 28, 2017 The oil pressure light turns off right away. I tightened my alternator belt today so it charges all the time now :), that seemed to make my headlights brighter too. Also am I supposed to use 10W-30 dello 400 and a FRAM oil filter? Is that what I hear? Maybe some Pensoil would be better? :) I used to use the NAPA WIX ones, but now I don't know. :) Quote Link to comment
Lockleaf Posted February 28, 2017 Report Share Posted February 28, 2017 No Fram. Ratsun house rule. I use the 15-40 delo in mine. 1 Quote Link to comment
captain720 Posted March 6, 2017 Author Report Share Posted March 6, 2017 Thanks. The wrecking yard has some 1999 dodge neon seats that they just got in, how much bracket fab would I have to do to make them fit? It looks like three of the four holes line up fine without any mods, how acceptable is it to only have three of the bolts installed? Quote Link to comment
captain720 Posted March 6, 2017 Author Report Share Posted March 6, 2017 They are out of pathfinder seats and I did read other threads, I just could not find out anything about actually making the bracket. Does anybody have pictures? Quote Link to comment
captain720 Posted March 26, 2017 Author Report Share Posted March 26, 2017 I am replacing CVs, shocks, and installing manually locking hubs tomorrow. Is there anything abnormal I have to do when I install the CVS? Quote Link to comment
captain720 Posted March 31, 2017 Author Report Share Posted March 31, 2017 I have been getting a large amount of wrenching done this week (spring break :thumbup: ) and I though it would be a good time for an update so here goes. I replaced my front axle. (sorry that is the old axle coming out with new one on the ground there, I am bad at taking mid project oics as I really get into it). New headlights (I did install, I just dropped it off for new all terrains when I took the pic). I also did shocks, belts, dropped off one of the hubs from lockleaf to be drilled out and re tapped, and bought new rear shocks. Also tomorrow I may be picking up a title less 720 for a parts truck. I will put more picks soon. Does anyone know about overload leafs for these rigs? I always find mine riding low when I overfill it :rofl: . 1 Quote Link to comment
Rhino13 Posted April 1, 2017 Report Share Posted April 1, 2017 Nice truck and good work so far, more than a lot of people get done that quick! Myself included... An add a leaf kit is simple and effective, it leveled my old truck out and stiffened up the rear. Quote Link to comment
captain720 Posted April 1, 2017 Author Report Share Posted April 1, 2017 Thanks Rino!! What add a leaf kit did you purchase? I picked up an 86 720 2wd kc for $300 last night and now I have to decide if I should use it for parts or try and get a title and slam it Quote Link to comment
captain720 Posted April 4, 2017 Author Report Share Posted April 4, 2017 Does any one have experience with the rock auto add a leafs? All I want is an increased load capacity, not a large ride height increase. If I do get a ride height increase will I need a custom drive shaft to not burn up U-Joints? Quote Link to comment
Rhino13 Posted April 4, 2017 Report Share Posted April 4, 2017 I believe I got them off jcwhitney but that was over 6 years ago so I'm not sure what brand. You really cant do much to increase the load capacity, but if you're trying to make it ride better with the load you could try air shocks. I think that'd be more bang for the buck rather than the add a leaf, especially if you don't want to raise it. Quote Link to comment
Lockleaf Posted April 4, 2017 Report Share Posted April 4, 2017 Add a leaf are specifically to increase the load capacity before bottoming out. Go to any auto parts store. They carry them on the shelf. Quote Link to comment
wayno Posted April 4, 2017 Report Share Posted April 4, 2017 Any added leaf will make the ride firmer when empty, so expect that or don't go that route as it is not adjustable. I added 2 extra leafs to my leaf pack from another 521 leaf pack, but I almost always have some kind of load in the flatbed, as it is my work truck, but every once in a while I fill it up with firewood, I installed overload air bags on the truck specifically for that, when ever I go get a load of wood I fill the bags before I leave, it's a rough ride getting there, but on the drive home my tires don't hit the underside of the flatbed, so it was worth the effort to install the bags, normally they have zero air pressure in them so they don't effect the ride, but when I load it up what little air that is in them does pressurize and it helps a little. Air bags are the only thing I know of that has little effect on the ride unless you put air in them, I also have coil over shocks, it is a work truck and it almost always has a trailer connected to it, if I didn't have the trailer, I would likely remove the coil overs, if I ever do retire, I will likely remove the extra leafs also, it is a built for a purpose truck. 2 Quote Link to comment
Rhino13 Posted April 4, 2017 Report Share Posted April 4, 2017 What are you going to be carrying that you'll need more carrying capacity? If its an all the time thing then the leaf will help make it ride better with the constant weight, if its an every once in a while thing consider air shocks or bags like wayno as you can let the air out and use your stock suspension for everyday driving. Quote Link to comment
captain720 Posted April 4, 2017 Author Report Share Posted April 4, 2017 I think I will go with the air shocks/bags as I carry bark and wood and bricks and yard waste and just random garbage. Now I am trying to decide which 720 I will carry more heavy stuff with. :rofl: Also trying to decide if I need the fancy air compressors and if I can afford them. :) 1 Quote Link to comment
Rhino13 Posted April 4, 2017 Report Share Posted April 4, 2017 Onboard compressors are nice, but if you have a compressor at home and will only be bringing these loads to and from your house they're not really necessary. Just route the air nipples by the license plate so you dont have to get under at all. Quote Link to comment
captain720 Posted April 18, 2017 Author Report Share Posted April 18, 2017 Nothing much has broken recently. :w00t: So I replaced my headlights and just did some preventative fixes/fix annoying things. Quote Link to comment
richamor Posted April 23, 2017 Report Share Posted April 23, 2017 I like your truck and admire your tenacity. :thumbup: But I would love to find a color matched shell for mine. Quote Link to comment
