Ignition Switch Wiring
FrankRizzo
I have a pushbutton start kit I want to try and install.
Can anyone help translate the wiring colors at the switch to what each one does (Batt, start, Ign, Acc)??
I cant figure it out from these (and multiple other searches) and it would save me some time next weekend.
I'm looking for what each wire color at the switch does. Thanks.
  • Replies 2
White is 12 volts from the battery
Black/White is 12volts to the fuse box and to the ballast resistor during ON and START
Blue/White provides 12 volts to wiper/washer/radio during ON and ACCY
Black/Yellow provides 12 volts to starter solenoid during START
Black/Red provides 12 volts to the coil during START
This better be one of those key fobs that knows when you are near the car and turns on automatically and all you do is push the button..
