FrankRizzo Posted February 12, 2017 Report Share Posted February 12, 2017 Does anyone know where I can get some of these I found these at the Z store, they look similar... http://www.thezstore.com/page/TZS/PROD/classic21a11/24-5133 thanks in advance. Quote Link to comment
FrankRizzo Posted February 12, 2017 Author Report Share Posted February 12, 2017 Im thinking these might be it. They are listed as "Hydraulic hose clip" but look pretty close https://www.rockauto.com/en/moreinfo.php?pk=1991030&cc=1210105&jsn=496 Quote Link to comment
flatcat19 Posted February 12, 2017 Report Share Posted February 12, 2017 Should be able to find a suitable replacement on the HELP isle of any parts store. 2 Quote Link to comment
Stoffregen Motorsports Posted February 12, 2017 Report Share Posted February 12, 2017 Hydraulic hose clips are usually thinner than parking brake cable clips. Flatcat is right about the HELP section. You could always use a c-clip or e-clip from the hdw store. 2 Quote Link to comment
FrankRizzo Posted February 13, 2017 Author Report Share Posted February 13, 2017 Thanx. My local Pep Boys has a full aisle of Help!...but nothing. I'll order from the Z car place and see what I get. I also ordered the ones from Rockauto since they were under $2.00 . Quote Link to comment
distributorguy Posted February 13, 2017 Report Share Posted February 13, 2017 The ones from Rockauto are thin, but have a stamped offset. You should be able to make them work. 1 Quote Link to comment
FrankRizzo Posted February 16, 2017 Author Report Share Posted February 16, 2017 For anyone's reference Left is original, middle is the Z Store clip and RIGHT is the rockauto/doorman hydraulic hose clip: 1 Quote Link to comment
FrankRizzo Posted February 16, 2017 Author Report Share Posted February 16, 2017 Ummmm..... I thought left was original ummm...lol. wut? Quote Link to comment
hobospyder Posted February 16, 2017 Report Share Posted February 16, 2017 :rofl: Quote Link to comment
distributorguy Posted February 16, 2017 Report Share Posted February 16, 2017 Do either of the replacements fit? Quote Link to comment
FrankRizzo Posted February 17, 2017 Author Report Share Posted February 17, 2017 Oh, I get it. I fixed it Hobo I'll find out this weekend, but the Z Store clip looks like an exact match. . 1 Quote Link to comment
wayno Posted February 17, 2017 Report Share Posted February 17, 2017 If it doesn't fit PM me, I have a shitload of them clips, but even though the middle clip gap looks slightly smaller, it will spread out enough to work. All them clips are the same from the 520/521 thru the 720 trucks, there are only 2 or 3 different clips, and they all have different uses. Quote Link to comment
FrankRizzo Posted February 19, 2017 Author Report Share Posted February 19, 2017 As Wayno notes....The Z clips are just a tad too small ID for the 620. You need a die grinder to make them work or spread them open a bit. I emailed RockAuto earlier in the week because the pic of the Isuzu Trooper rear cable on their website clearly shows a clip and none of my cables had one included. Surprise to me, the sent me a whole new cable AND the clip. Ive gotten soooo much info from here, I thought the least I can do is update the picture to show the clip you need to correctly adapt the Isuzu rear disk cable to the 620 chassis bracket if someone is searching. This is for rear disks and you are trying to hook up the parking brake. Or you can spread open a Z clip. The Isuzu clip is on the right. . Quote Link to comment
