Kenmataya Posted February 8, 2017 Report Share Posted February 8, 2017 and.... so i pulled the cover I guess the wet floorboards make sense now..... Ken Quote Link to comment
datzenmike Posted February 8, 2017 Report Share Posted February 8, 2017 Looks like water getting in. Actually it looks like mostly water from the bubbles. Better find out where it getting in and fix or stop driving through 3' of water. :lol: Have you ever changed the oil? If so the problem happened since then. If not is it possible a PO may have submerged the transmission? Water will displace/dilute oil so it will likely come out the striking lever the shifter is connected to. Possibly where it's getting in too as there is only the bottom cover and the fill bung. Haven't seen bubbles before. The ones I saw with water were like milky/gray margarine 1 Quote Link to comment
