Fast510 Posted February 26, 2017 Report Share Posted February 26, 2017 Will this work for my set-up? I have the 300zx in the front and the rears are either Isuzu or Pathfinder. Will the Brake Booster also need to be upgraded? Quote Link to comment
sebpv Posted February 26, 2017 Report Share Posted February 26, 2017 why would it not work? Its a brake upgrade. It will only brake more efficiently. If you're referring to the fitment: Fok Nhoz Quote Link to comment
FrankRizzo Posted February 27, 2017 Author Report Share Posted February 27, 2017 You have to upgrade the headlight on your vacuum cleaner first. . Quote Link to comment
datzenmike Posted February 28, 2017 Report Share Posted February 28, 2017 All brakes work, and if you have stock drums or 300zx 6 piston calipers locked up in a panic stop the distinction becomes moot. Tire grip or traction to the road becomes the determining factor on how short a distance you can stop, and not really so much the brakes used. That said, disc brakes are somewhat easier to bring to, and hold at the edge of tire lock up better than drums even when they are perfectly adjusted. And this only applies if you have time and distance to get stopped. There's a big difference between how short a distance you can get stopped in, and when that distance is less than you need and you know you are not going to make it. As I said earlier, in a panic situation the brakes go on with maximum effort there is no time to modulate the brakes, they lock and the tires slide on melted rubber. Six piston calipers on 13" vented cross drilled rotors are not going to save you. In comparison to drum brakes, disc brakes are simpler, less parts (to go wrong) and easier to replace pads. They require basically no adjusting and although almost never exposed to severe prolonged braking are very resistant to heat fade. So what is gained from larger calipers and pads and larger diameter vented rotors? Well not much as 'all brakes work' but they do give some peace of mind. Some extra measure of assurance you could stop a freight train if you had to. The biggest day to day advantage might be they are easier to use with less pedal effort. Quote Link to comment
FrankRizzo Posted March 1, 2017 Author Report Share Posted March 1, 2017 13.5" disks (2 piece) with 6 piston calipers.... ...strictly for reference... Brake jobs are expensive. "Replace rotors and pads"... Quote Link to comment
datzenmike Posted March 1, 2017 Report Share Posted March 1, 2017 If the rotors are that expensive they can be turned for less. In some cases new is cheaper. I had a Dodge Onmi. $18 to turn a rotor and $20 new. Yes they can be expensive... but paragraph two in my last post. It's only money. Quote Link to comment
Rick-rat Posted March 1, 2017 Report Share Posted March 1, 2017 They are Isuzu in the rear and I think they are the Hardbody in the front. . That is what I had on my 73, Napa shows new 15/16 MC with reservoirs for $277.00. 79 280 ZX Quote Link to comment
FrankRizzo Posted March 1, 2017 Author Report Share Posted March 1, 2017 That is what I had on my 73, Napa shows new 15/16 MC with reservoirs for $277.00. 79 280 ZX They wont have it in stock. The 15/16 M/C from Arizona Z is $129.00 Quote Link to comment
datzenmike Posted March 1, 2017 Report Share Posted March 1, 2017 What someone needs to do is buy up all the rebuild kits. Are there any available? Quote Link to comment
Stoffregen Motorsports Posted March 1, 2017 Report Share Posted March 1, 2017 I don't think those rotors can be turned. Pretty sure they can be ground, like a flywheel. But turning them with a cutting bit, the slots create cutting problems. Quote Link to comment
FrankRizzo Posted March 2, 2017 Author Report Share Posted March 2, 2017 I don't think those rotors can be turned. Pretty sure they can be ground, like a flywheel. But turning them with a cutting bit, the slots create cutting problems. yeah, they are two piece. They sell brake "kits" that include the pads and rotors for each axle. Quote Link to comment
