PL510425584 - 1973 2 door 510 "WANABRE"
five1oh
  • Replies 65
Small update.....when you go full bre it can't be full bre without decals, right??? I haven't installed all of the decals yet but I am loving how #wanabre is turning out.
33442828362_7248586534_b.jpgUntitled by five1oh2010, on Flickr
32785576713_626449ffa8_b.jpgUntitled by five1oh2010, on Flickr
Also managed to get the rear ready for my 280zx rear disc conversion. Decided to cut off the backing plate since I didn't want to mess with the rear bearings or stub shaft. While in there I found out my drivers side axle shaft had a broken u-joint so I pulled that out for repair or replacement. Now I'm just waiting on my front 280zx coilovers, calipers, rotors, and pads from the510keeper to finish this up and have working brakes and get it as low as I want it. I also fixed my drivers door as it wouldn't latch due to a bad spring. Getting there....
33470517471_3bb5f38d4c_b.jpgUntitled by five1oh2010, on Flickr
33558895896_7fa89e570c_b.jpgUntitled by five1oh2010, on Flickr
32785575153_c1ce8b306a_b.jpgUntitled by five1oh2010, on Flickr
32785573753_33e06981ff_b.jpgUntitled by five1oh2010, on Flickr
33558896726_91ca48b128_b.jpgUntitled by five1oh2010, on Flickr
So I got to spend all day today working on the 510. I took yesterday off and drove up to see the keeper for some parts: 280zx front shortened struts with coilovers, camber plates, brakes - the works! / a hood release cable because mine rusted and broke / rear axle shaft, and some patch panels .
Managed to finish installing the rear 280zx disc brake conversion, axle shaft, and front strut assemblies with everything. My wife helped me bleed the brakes and I would've been on the ground but unfortunately I need some wheels spacers for the front.....so hopefully later this week. Anyways onto the pics:
What I was rocking before.......it was pretty hard to stop with these since I had no rears
33742870126_fe96bd1ef7_b.jpgUntitled by five1oh2010, on Flickr
33654287891_a76c765168_b.jpgUntitled by five1oh2010, on Flickr
New rears!!!
33654295061_a932f3a1cf_b.jpgUntitled by five1oh2010, on Flickr
33783670235_f1ceff337c_b.jpgUntitled by five1oh2010, on Flickr
Fronts done:
33783669145_16deaa614d_b.jpgUntitled by five1oh2010, on Flickr
33398958710_e1b3a1da82_b.jpgUntitled by five1oh2010, on Flickr
Contact.....arrrghhh wanted to drive it so bad.
33627190772_30fe2d9edc_b.jpgUntitled by five1oh2010, on Flickr
33742854256_66f9c76e68_b.jpgUntitled by five1oh2010, on Flickr
Also got this in the mail today
33399042950_f948df8a80_b.jpgUntitled by five1oh2010, on Flickr
  • Like 3
My wheel spacers came in yesterday and I put them on with no issues. Got the car on the ground and wow!! I love the way it looks
Drive went well but still have a couple things to button up. Gonna lower the front a bit more, secure the rear brake lines, possibly swap rear ends, and then I will start driving a bunch weather permitting.
Some pics:
33885961685_464158c5be_b.jpgUntitled by five1oh2010, on Flickr
33885965515_23c46191f1_b.jpgUntitled by five1oh2010, on Flickr
33756461741_659c6a173b_b.jpgUntitled by five1oh2010, on Flickr
33729161542_264a97c8df_b.jpgUntitled by five1oh2010, on Flickr
33042085254_e8d012e24c_b.jpgUntitled by five1oh2010, on Flickr
33729154822_45b5205668_b.jpgUntitled by five1oh2010, on Flickr
33042071554_7938454da4_b.jpgUntitled by five1oh2010, on Flickr
33501068850_e161183841_b.jpgUntitled by five1oh2010, on Flickr
33072390433_b575781dab_b.jpgUntitled by five1oh2010, on Flickr
33501064600_57155ccb5a_b.jpgUntitled by five1oh2010, on Flickr
  • Like 3
Thanks guys!
I spent some time working on the car today. Managed to remove my extremely hairy rear end and put one I've been carting around since '99 (came with parts for my second 510). It had 3.9 lock written on it. The rear end in the car had a lot of play and made some noises so decided to swap it. It was a big pain to remove but once I found the shims under all the grime and got those out it made it a much easier task. I also managed to secure my rear brake lines and when I was all done took it on the freeway. Rear end worked well but 5th gear is making a bunch of noise but didn't pop out of gear. I will most likely be changing the trans soon.... now I have posi so it should make for some fun driving :)
33560975740_b11ca9011d_b.jpgUntitled by five1oh2010, on Flickr
33102895474_e7cb313718_b.jpgUntitled by five1oh2010, on Flickr
33946212885_c07e3a08ee_b.jpgUntitled by five1oh2010, on Flickr
33946211055_90ccf3a454_b.jpgUntitled by five1oh2010, on Flickr
  • 4 weeks later...
After driving it a few weeks back I realized the 200sx dogleg transmission needed to be replaced. Thankfully when I bought my 280zx struts from James I told him I wanted the 5 speed out of the donor 280zx he picked up. After a couple weeks of begging he gave in and let me buy it. At that point I started preparing for the next phase. I picked up a crossmember and bushing from Troy and took my driveshaft in to be shortened.
While I was waiting for that I decided to get rid of the ugly paint the previous owner painted over the sill trim. It was a pain in the ass to remove but so thankful I did. Changed the look completely:
34480188106_7da90857db_b.jpgUntitled by five1oh2010, on Flickr
34391253811_6b3413909a_b.jpgUntitled by five1oh2010, on Flickr
34521488045_358212770a_b.jpgUntitled by five1oh2010, on Flickr
I also took the opportunity to change out the water inlet tube and the alternator:
34480188576_b367270077_b.jpgUntitled by five1oh2010, on Flickr
I also decided I needed to paint the white section on the tail panel:
34360668402_51c84c7fd7_b.jpgUntitled by five1oh2010, on Flickr
34360665602_505a1467dc_b.jpgUntitled by five1oh2010, on Flickr
34521525945_9443d62d3a_b.jpgUntitled by five1oh2010, on Flickr
  • Like 3
While my car was in the air I also decided to try and refinish the wheels myself. In addition you will notice I replaced the front signals with clear ones. All the years I've owned 510's I've always wanted a set and was eventually going to have my own made until I saw a set on eBay recently. The quality isn't amazing but it is good enough to run and I like the way it looks.
34135747800_67a1136ffc_b.jpgUntitled by five1oh2010, on Flickr
34135752150_a4fe06dab7_b.jpgUntitled by five1oh2010, on Flickr
34391288761_3abd5b4595_b.jpgUntitled by five1oh2010, on Flickr
34135748550_de518d0098_b.jpgUntitled by five1oh2010, on Flickr
33710995573_9ea6a76a6d_b.jpgUntitled by five1oh2010, on Flickr
Better than they were but not super good. I normally would have had them professionally powdercoated but didn't want to spend the money. While I was waiting I also completed the front spoiler and it turned out awesome for rattle can:
34480227656_5705f92380_b.jpgUntitled by five1oh2010, on Flickr
34135746840_0e161e669e_b.jpgUntitled by five1oh2010, on Flickr
33678862174_72001a6671_b.jpgUntitled by five1oh2010, on Flickr
Measured my marker holes for fillage!!!!
34135744340_67df8d49da_b.jpgUntitled by five1oh2010, on Flickr
33678865594_1f153f3886_b.jpgUntitled by five1oh2010, on Flickr
Just a day before we were set to swap the trans my plate came in so I restored a Manteca Datsun license plate frame I had:
34521530745_377dbcf1bd_b.jpgUntitled by five1oh2010, on Flickr
Picked up the trans from james and cleaned it up a little:
34521531005_bd32a4b822_b.jpgUntitled by five1oh2010, on Flickr
Unfortunately I didn't take any pics of the swap because I was covered in grease. My friend Eric drove 2 hours to help me put it in. It took about five hours start to finish by the time it was back on the ground (this included welding up my side marker holes). Unfortunately I got some bad info and we used the wrong collar, had to start all over at 6pm. Finished it at about 10pm and then messed with the wiring to my lights so we could take it for a spin. Good thing we had no issues because in the excitement Eric and I didn't bring cell phones or tools with us. We only had one working headlight and I didn't even have my license on me, anyways it ran pretty good and had a few vibrations. Earlier I noticed that the geniuses at Big O mounted two of my tires the wrong way..... I did manage to get a pic of Eric grinding my shaved markers:
33710994943_a909d0c6a3_b.jpgUntitled by five1oh2010, on Flickr
The next morning I was so excited I had to drive it to work. While doing the trans I also took the liberty to lower it another inch :) Next pic is a video if you click you can see. I can't believe this is the same car!!! It still has the rust holes but looks a million times better in my opinion....maybe the stickers distract from the issues lol:
Video:
33678931264_2cd41f93c9_b.jpgUntitled by five1oh2010, on Flickr
Work pics:
34521550855_f0bcfc993c_b.jpgUntitled by five1oh2010, on Flickr
34135781070_af80810e34_b.jpgUntitled by five1oh2010, on Flickr
34391326721_084d2dd796_b.jpgUntitled by five1oh2010, on Flickr
34391324251_cbdea9fc06_b.jpgUntitled by five1oh2010, on Flickr
33678884494_c568986bed_b.jpgUntitled by five1oh2010, on Flickr
34135804260_952010b80a_b.jpgUntitled by five1oh2010, on Flickr
34391351511_84f659bb6b_b.jpgUntitled by five1oh2010, on Flickr
Made it home!!!! Then I took the two wheels off and had Big O fix they're mistake. I also put my center caps back on and added some Datsun valve stems
33711027823_02a7e06f45_b.jpgUntitled by five1oh2010, on Flickr
  • Like 3
Today I decide to clean up my pillar vents. I also drove it a ton this weekend. No super long extended freeway cruising but was on and off the freeway a lot. Probably drove a couple hours and am happy to report the alternator worked well and the car didn't have any overheating issues :) . Currently the only working gauge is the temp gauge (which is a plus) and the charge light. Need to get the fuel gauge working and will be swapping in my other cluster with tach :)
33711045453_f8c4ebc377_b.jpgUntitled by five1oh2010, on Flickr
34360679452_cb54af9f27_b.jpgUntitled by five1oh2010, on Flickr
34360679132_e60192e696_b.jpgUntitled by five1oh2010, on Flickr
34135801300_758abd2534_b.jpgUntitled by five1oh2010, on Flickr
As you can imagine this car attracts a lot of attention and I love seeing people drive by honking and smiling. Even passed a cop today and didn't get pulled over. Need to put my side mirrors on soon...
Next up is front grill clean up, side mirrors, and some dash and interior work :)
Happy 510 day everyone!!!!!!!!!!!!  It feels so good to be back in a 510.  Last year was the first and only one I missed in the past 20.  So thankful this car fell into my lap.  Took it to a small meet in Vacaville last night and to be honest was worried I would break down.  Happy to report I had no issues but definitely need to fix some wiring soon as I only have 1 headlight, no blinkers, and no fuel gauge.
VIDEO (if you click link):
33766121993_2f3eb21371_b.jpgUntitled by five1oh2010, on Flickr
33766043393_4616fd0b36_k.jpgUntitled by five1oh2010, on Flickr
34576237575_4d3411cb9f_k.jpgUntitled by five1oh2010, on Flickr
34576236725_550fa0d6a4_k.jpgUntitled by five1oh2010, on Flickr
34414297272_4ed2b65938_k.jpgUntitled by five1oh2010, on Flickr
33733361034_279c23dcff_k.jpgUntitled by five1oh2010, on Flickr
  • 3 weeks later...
So I got some more stuff done in preparation for datslocos. Finally got around to cleaning up the grill. Really happy how it turned out but unfortunately snapped off the mounts for the Datsun emblem when trying to remove....will have to fix that later. I ended up stripping all of the paint off the grill and headlight surrounds. Unfortunately my headlight surrounds were blasted previously so I decided to paint them with chrome paint.....not to happy with how they turned out but I have some good ones on the way so will eventually replace. I also masked and decided to give myself some custom hood and fender trim lol
34897913165_29082b041d_b.jpgUntitled by five1oh2010, on Flickr
34897917325_9afdac29e1_b.jpgUntitled by five1oh2010, on Flickr
34055303844_a77e3772f7_b.jpgUntitled by five1oh2010, on Flickr
34897916565_f98d41b311_b.jpgUntitled by five1oh2010, on Flickr
34087526363_c600c643d7_b.jpgUntitled by five1oh2010, on Flickr
34766346181_9320167539_b.jpgUntitled by five1oh2010, on Flickr
34766350371_aaeb71e22d_b.jpgUntitled by five1oh2010, on Flickr
Also got around to putting the interior back in. First up was filling the hole from the tranny swap so I don't get hot air blowing on me all the time. Got an old license plate, some wire snips, and a rivet gun and done. Really happy with how it turned out. Put my door cards on and put my rear seat in along with the front section of carpet. Also mounted my Renown steering wheel and rare horn button with championship wreath. Also installed my trans am champion wood shift knob. I won't have the dash in by datslocos but that will be next. I have a factory tach cluster, uncut stereo mid section with tray, and a glove box section with 2.5 emblem to finish it off.
On to the pics....
34055306454_6fb65867d1_b.jpgUntitled by five1oh2010, on Flickr
34511253020_49aea48e2f_b.jpgUntitled by five1oh2010, on Flickr
34087525713_bb2eefc3a1_b.jpgUntitled by five1oh2010, on Flickr
34055305654_40cb3c1e96_b.jpgUntitled by five1oh2010, on Flickr
34087527673_66c5b45762_b.jpgUntitled by five1oh2010, on Flickr
34766349911_1bc0b3e2b5_b.jpgUntitled by five1oh2010, on Flickr
34087527653_48f65f67cc_b.jpgUntitled by five1oh2010, on Flickr
34897911225_328fbf1190_b.jpgUntitled by five1oh2010, on Flickr
34897917525_47763f22e6_b.jpgUntitled by five1oh2010, on Flickr
