Rocky671 Posted January 20, 2017 Report Share Posted January 20, 2017 Can anyone point me in the right direction please???I am looking for 30 over ka24 pistons.Thank you in advance. Quote Link to comment
G-Duax Posted January 20, 2017 Report Share Posted January 20, 2017 eBay......... Quote Link to comment
datzenmike Posted January 20, 2017 Report Share Posted January 20, 2017 KA24E or KA24DE? 240sx have floating pins, the trucks are pressed in.. Early S13 KA24E were slightly domed. Quote Link to comment
Lockleaf Posted January 21, 2017 Report Share Posted January 21, 2017 That is about.76mm. Try looking for them in mm. O'Reilly Auto lists a part number for d21 kae pistons in 0.5mm and 1.0mm oversize. Try rock auto. Look up Clegg machine website. They sell rebuild kits at good prices including the option to oversize Quote Link to comment
Rocky671 Posted January 21, 2017 Author Report Share Posted January 21, 2017 thank u guys.i want to put ka24 pistons into a z24 that i am currently rebuilding.what is best ka24e or ka24de??? Quote Link to comment
Lockleaf Posted January 21, 2017 Report Share Posted January 21, 2017 You would definitely need to use d21 pistons unless you wanted to make further modifications. What goal are you trying to achieve? Quote Link to comment
datzenmike Posted January 21, 2017 Report Share Posted January 21, 2017 KA24DE piston won't fit. KA24E do have the same pin height and your compression would be 9.52 with a stock piston and 9.67 with a 1mm oversize piston. Be sure to check the width of the Z24 rod small end inside the KA piston. There has to be enough room for the piston to center itself over the rod bearing. I'm saying you may need to machine the Z24 rod small end slightly narrower. I'll find one of my old KA and Z24 rods and measure them tomorrow.. 1 Quote Link to comment
Rocky671 Posted January 21, 2017 Author Report Share Posted January 21, 2017 thank you for u guys's help Quote Link to comment
Doctor510 Posted January 21, 2017 Report Share Posted January 21, 2017 Bernice Romero Evergreen Automotive 1527 Chico Avenue South El Monte, CA 91733 (626)580-0638 (626)582-1513 (626)582-1512 Quote Link to comment
datzenmike Posted January 21, 2017 Report Share Posted January 21, 2017 KA24E rod small end width 240sx S13.................... 0.985" these have the full floating pins D-21 Hardbody............. 0.865" these use regular press in pins. The Z24 you'll have to measure yourself. It's important that the rod/pin be able to slide side to side in the piston. Quote Link to comment
Rocky671 Posted February 22, 2017 Author Report Share Posted February 22, 2017 how do i know if i need floating or pressed on pistons??? Quote Link to comment
Rocky671 Posted February 23, 2017 Author Report Share Posted February 23, 2017 just saw ur comment about the trucks having pressed pistons.So i take it i need pressed pistons lol Quote Link to comment
datzenmike Posted February 23, 2017 Report Share Posted February 23, 2017 Yes truck are pressed in. Quote Link to comment
Rocky671 Posted February 23, 2017 Author Report Share Posted February 23, 2017 thank you for all your help @datzenmike Quote Link to comment
