CGraves Posted February 1, 2017 Report Share Posted February 1, 2017 For anyone watching this topic, I have a question: Is there a bracket or something to support an airdam? There's NOTHING under there for this car, and I don't know these cars. If there is a bracket, is there anywhere I can get one? If you mean something to support the middle then nope. It should just bolt/screw into the sides under the side markers. 1 Quote Link to comment
datzenmike Posted February 1, 2017 Report Share Posted February 1, 2017 The 71C is hands down a stronger transmission. To use it you will need to swap an L series front case onto it. There is more to this but can be done easily enough. The 71C is not the same length so the driveshaft will need modifying. The L series use of the 71B comes in three flavors as far as gear ratios.... ...........WIDE......MID.......CLOSE 1st..... 3.592.... 3.321.... 3.062 2nd.... 2.246.... 1.902.... 1.858 3rd.... 1.415..... 1.308.... 1.308 4th.... 1.000..... 1.000.... 1.000.............................. ALL 4TH GEARS ARE THE SAME RATIO 5th..... 0.813.... 0.833.... 0.773 or 0.745 WIDE...... Builds RPM fast on take offs, larger RPM drop on shifts, 19% drop into 5th for mileage. Good for heavy vehicles or trucks or small displacement engines. Must down shift to 4th to accelerate to pass or climb hills. MID......... Good all round ratios, only 14% drop into 5th. Least need to downshift to 4th when passing. CLOSE... Slower to build RPMs in first, least RPM drop between shifts, 26% drop into 5th making it only useful for saving gas while cruising. Use with 4 cylinder in light car or six cylinder in heavier. Absolutely MUST downshift to accelerate. This is for L series 71Bs. If later Z or CA series 5 speeds, there are some minor changes to the 3-4 shift on the WIDE and MID ratio boxes. Quote Link to comment
CobaltFire Posted February 1, 2017 Author Report Share Posted February 1, 2017 The 71C is hands down a stronger transmission. To use it you will need to swap an L series front case onto it. There is more to this but can be done easily enough. The 71C is not the same length so the driveshaft will need modifying. The L series use of the 71B comes in three flavors as far as gear ratios.... ...........WIDE......MID.......CLOSE 1st..... 3.592.... 3.321.... 3.062 2nd.... 2.246.... 1.902.... 1.858 3rd.... 1.415..... 1.308.... 1.308 4th.... 1.000..... 1.000.... 1.000.............................. ALL 4TH GEARS ARE THE SAME RATIO 5th..... 0.813.... 0.833.... 0.773 or 0.745 WIDE...... Builds RPM fast on take offs, larger RPM drop on shifts, 19% drop into 5th for mileage. Good for heavy vehicles or trucks or small displacement engines. Must down shift to 4th to accelerate to pass or climb hills. MID......... Good all round ratios, only 14% drop into 5th. Least need to downshift to 4th when passing. CLOSE... Slower to build RPMs in first, least RPM drop between shifts, 26% drop into 5th making it only useful for saving gas while cruising. Use with 4 cylinder in light car or six cylinder in heavier. Absolutely MUST downshift to accelerate. This is for L series 71Bs. If later Z or CA series 5 speeds, there are some minor changes to the 3-4 shift on the WIDE and MID ratio boxes. Thanks for this, this is what I had understood. The intention is that if we need a transmission we will be using a 71C. Quote Link to comment
CobaltFire Posted February 1, 2017 Author Report Share Posted February 1, 2017 Updated the main post. Quote Link to comment
CobaltFire Posted June 22, 2017 Author Report Share Posted June 22, 2017 So after a very busy past few months I haven't made much progress. Life is getting too busy with my career and the new addition. Car is going to be put up for sale. As of now I think I'm going to part it out, unless I get a reasonable offer for everything. I'll post a for sale ad soon; I don't think I'm keeping anything as I don't have another Datsun for anything to go to. Quote Link to comment
Dr ZED Posted June 22, 2017 Report Share Posted June 22, 2017 You're in southern California so I would think somebody would be happy to buy up the whole car with parts for a decent amount. Quote Link to comment
InitialBoss Posted November 4, 2017 Report Share Posted November 4, 2017 Did you end up selling the car? Quote Link to comment
CobaltFire Posted November 8, 2017 Author Report Share Posted November 8, 2017 I did not, actually. It's been half-assedly listed for sale for a while now, but my heart isn't in it. I have what seems to be a possible fair offer on the induction system (Mikuni's, rebuild kits, K&N filters, velocity stacks, manifold, linkage), and I'm actually picking the car up and bringing it to SoCal this weekend to tear into it a bit and see if I can't Ratsun it out a little. 1 Quote Link to comment
CobaltFire Posted November 16, 2017 Author Report Share Posted November 16, 2017 So a quick update: The car is now housed in a friend's garage in San Diego, and it is WAY less rusted than we thought. I had a buyer for the Mikuni's, but they backed out after lowering their offer twice (to a low of $900 for everything). I also had a buyer for the wheels, but without the free cash from selling the Mikuni's I couldn't sell the wheels to put anything else on it! So where I stand now is that it's here, it's way more solid than we thought, and we are going to be cleaning it up and stripping the interior this weekend. I'd still LIKE to sell the induction system (I really prefer EFI), so I'll probably relist it for $1600 or so and see if anyone is interested. The transmission needs the shifter rebuilt, but everything seems to WORK: brakes, clutch, suspension, etc. All the body panels are straight, and the rust (at this time) seems to be limited to surface everywhere except the front rear lower quarters in front of the wheel wells, the aft bottom of the front fenders in front of the doors, the bottom of the doors themselves, and the panel above the tailights. The cabin floors are solid with one exception where my uncle (who was almost 400lbs) overstressed a seam and tore it a bit after it rusted. We will be welding that back together. I'm going to take pictures, then we are soda blasting it this weekend to see how bad those areas are. However, they all feel pretty solid, only two are for sure rusted thru. We intend to get the car back up and running over the next 90 days or so, budget willing. I'll be posting a full update to the main post this weekend with pictures of the car as it is and after some cleaning. Quote Link to comment
CobaltFire Posted November 20, 2017 Author Report Share Posted November 20, 2017 Quick note; forgot to take pictures! I'll update the main post once I get a few pictures. Took out everything in the interior minus the dashboard. TONS of speaker wire from what I'm told was a pretty big stereo in the 90's. The tear on the drivers floor is ~12" long, but once pushed back into place is maybe 1/4" wide. Not too bad. The passenger side has a hole the size of a quarter or maybe a little less. The section above the taillights is pretty much gone; maybe 40% of the metal remains. Spare tire well is BRIGHT orange with rust, but feels solid; going to blast it and see. The entire hatch area is covered in road grime or exhaust grime (or some combination), but it started coming off pretty well with dish soap and water, leaving us with a very nice original orange interior back there, aside from the areas that need repaired. I'm seeing the same up front as well, though it looks like there is more wear on the paint. We did a test soda blast of the passenger side rear lower wheel well in front of the wheel/behind the door, as that was very obviously rotten thru. That blaster worked like a charm, and we were even able to take down the paint coat by coat, revealing that the car was originally 918 Orange, then got repainted white, then repainted black over that. I ordered some throttle bodies off of a Triumph 675; we intend to build a stub manifold and attach those then run that via either MegaSquirt or Speeduino. I'm also going to LS coils. Sorry to the guys who like the classic stuff; I just don't know it. I priced out going to Jenvey's, and it's a possibility but it ended up being almost $1500 more compared to the Triumph TB's, best case. $85 each set shipped, came with 300cc injectors, TPS sensor, fuel rail, and trumpets. They also have a stepper IAC motor, which I may or may not be able to get running. They have an 83mm center to center, so they are VERY close to being straight shots on the outer ports (8mm offset on those) and only slightly worse on the center port (13.5mm). If anyone knows of an off the shelf stub manifold, or even a blank intake manifold flange, that I can buy reasonably, let me know. The cheapest I've found is $300 and I'd rather fab one than pay $300 for a flange. Quote Link to comment
Bleach Posted November 20, 2017 Report Share Posted November 20, 2017 If you add pictures to your first post, please also add them to the end of your thread here for those of us who are looking at new posts only. :) Quote Link to comment
CobaltFire Posted November 20, 2017 Author Report Share Posted November 20, 2017 If you add pictures to your first post, please also add them to the end of your thread here for those of us who are looking at new posts only. :) I'll make sure to do so! Quote Link to comment
CobaltFire Posted November 27, 2017 Author Report Share Posted November 27, 2017 Another quick update without pictures: Picked up a set of Enkei Compe 16x8 +0 wheels for a pretty good discount off of facebook and the Western Minilites are leaving today. Putting some 225/50r16 Potenza RE760's on the car next week (it'll have to sit in the air for a week or so). Working on the stub manifold for the Triumph throttle bodies. Those things were really a steal! 300cc injectors, fuel rail, TPS, MAP sensor, velocity stacks, and all three TB's in excellent condition for $85 (averaged) each! Building a stub manifold out of aluminum and then use some fuel filler hose with a 2" ID (same as the TB's) to link the TB's up to the stubs. That should be flexible enough to let me make the mild curves needed. Building a heat shield into the stub manifold, then wrapping each hose in some heat shield blanket material. Also building in some adjustable stays to hold the TB's at the end of the hoses so no droop. Using a standard K&N oval filter with a sandwich setup, basically like what on there now. Hoping to put some pictures of this up soon. Looking at seat options; I may just end up going stock for the moment but I need to find a set for a decent price. Could also use some input on the trigger wheel setup. I've seen the Hoke Performance one and that looks to be the best bet at this time. I'm intending to go MegaSquirt with LS Coils. Any input from the hive mind there? Quote Link to comment
