idle problem
  • Please log in to reply
9 replies to this topic
#1 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
  • Cars:1984 Nissan 720 4X4
Posted 10 January 2017 - 11:03 AM
when its cold than it will idle at around 1200 rpms, but when it warms up to operating temperature, it will "buggle" and almost die down to 200 and jump to about 2000 then slowly go back down to 200. BUT... whenever I step on the clutch then the idle will even out at 2100 rpms and be steady. W......T.......F....?????????? doesn't make any sense. yeah i would understand if it was in gear but its always in neutral. (yes it does happen in gear as well) any ideas
#2 racerx
racerx
  • Senior Member
  • PipPipPipPipPip
  • 4,431 posts
  • Cars:71 Datsun 510 and 65 Mustang Fastback
Posted 10 January 2017 - 01:25 PM
kind of vehicle, type of carburetor?
#3 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
Posted 10 January 2017 - 01:29 PM
1984 Nissan 720 4X4 manual transmission with Hitachi carb, Z24 engine
#4 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,058 posts
Posted 10 January 2017 - 02:04 PM
I assume you ck the cable  to make sure not binding and lube it up. Carb binding also?
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
#5 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
Posted 11 January 2017 - 01:21 PM
what cables are you referring to exactly, Im not too familiar with this carb just yet.
#6 asid99
asid99
    Newbie
  • New Members
  • Pip
  • 20 posts
  • Cars:1981 Datsun 720, 1970 Datsun 510
Posted 12 January 2017 - 08:15 AM
Is it slowly bogging out, or is it like turning off? If its bogging I would replace the jets and check the float. If it is turning off, I could do a cap and rotor replacement...if that doesn't work, I would change lead wires and plugs......and if that fails again, pray.
#7 asid99
asid99
    Newbie
  • New Members
  • Pip
  • 20 posts
Posted 12 January 2017 - 08:17 AM
before you try any of those though, check the bottom cover to the steering wheel. It can come loose over time and pull on your ignition wires.
#8 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
Posted 20 January 2017 - 10:01 AM
no its jumping from 1200 rpms to about 2200 rpms when its warmed up, BUT when I put the Clutch in, It will steady out... Im just trying to figure out why my clutch has a role in changing the rpms while in neutral.
#9 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,302 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 20 January 2017 - 03:50 PM
The clutch is part of the emissions system.
Posted Image
#10 asid99
asid99
    Newbie
  • New Members
  • Pip
  • 20 posts
Posted 29 January 2017 - 09:53 PM
Check your clutch fluid resivoir, it can be low. I was having the same problem and it turned out to be my hydrolic cable and slave.
