fuel sending unit Question
  • Please log in to reply
11 replies to this topic
#1 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
  • Cars:1984 Nissan 720 4X4
Posted 10 January 2017 - 10:43 AM
so, I decided to get a new fuel gauge and decided to rewire it, ( the previous owner thought that they were an electrician and completely messed with the wiring) I am going to drop the fuel tank and rewire the fuel sending unit and the fuel pump, which leads me to this question.... Does any one know if there are common problems with the fuel sending unit going out, or are they pretty durable? the reason I am not fixing the old one is because the previous owner also screwed with the wiring inside the engine as well. and if anyone has a wiring diagram for the sending unit and pump to gauge and power please let me know,, Thanks
ToxicDepression
#2 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 10 January 2017 - 10:47 AM
Fuel sending units are pretty durable in these. I'm not sure I've come across a single person who had to replace one.
What year is your truck?
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#3 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
Posted 10 January 2017 - 11:06 AM
its a 1984 4X4, with the z24 engine
#4 asid99
asid99
    Newbie
  • New Members
  • Pip
  • 20 posts
  • Cars:1981 Datsun 720, 1970 Datsun 510
Posted 12 January 2017 - 08:36 AM
ToxicDepression
Im not sure about the sending unit, but mine had a problem with the pump. It lost its compression abilities. It would make sound when you turned it on, but didn't have the power to keep up with the engine's needs, causing it to bog out. I however need to redo my gauges so if you could, please show how you do it. I am shitty when it comes to gauges.
#5 la_leo
la_leo
    Advanced Member
  • Members
  • PipPipPip
  • 248 posts
  • Cars:Built in Feb 1985 Nissan 720 4x4 ST
Posted 14 January 2017 - 11:59 AM
I have a question on this issue. Where do the wires from the fuel sending unit go? I think I'm getting a short in between the fuel sending unit and the guage. It worked intermittently for a while but now not at all.
#6 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
Posted 14 January 2017 - 12:03 PM
They go to the top of the fuel tank, through a hole under the passenger seat in the cab.
#7 la_leo
la_leo
    Advanced Member
  • Members
  • PipPipPip
  • 248 posts
Posted 15 January 2017 - 03:50 PM
And then directly to the dash ? Or is there a relay
#8 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
Posted 15 January 2017 - 04:13 PM
There is a voltage regulator built in to the back of the gauge bezel, but other than that, it is a straight shot I believe. Look up a wiring diagram, or a FSM for your truck.
#9 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
Posted 20 January 2017 - 09:58 AM
so I got everything wired and put together but I believe I have the wrong fuel gauge, does anyone know what resistance I will need on the fuel gauge ( or type of gauge)
#10 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
Posted 20 January 2017 - 11:33 AM
Do you have an aftermarket gauge?
#11 ToxicDepression
ToxicDepression
    Newbie
  • New Members
  • Pip
  • 16 posts
Posted 20 January 2017 - 12:53 PM
yes, I believe they gave me the wrong one
#12 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,359 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 20 January 2017 - 05:07 PM
Intermittent. Well if not reading, then not a short. A short would read FULL all the time. No reading would be an open circuit. Like a lose connection.
Nissan fuel senders are wired this way ...
battery....> ignition switch...> gauge voltage regulator... > gauge... > sender in tank...>  ground.
The sender varies a resistance to ground with
10 or less ohms..... FULL (a wire that is grounded will read this)
24.5 ohms.............. 3/4
37 ohms................. 1/2
56.5 ohms.............. 1/4
80 or more ohms... EMPTY (a broken or disconnected wire will read this)
Posted Image
