Enrique20 Posted January 10, 2017 Report Share Posted January 10, 2017 So ive been searching a lot. I been looking for a solution to the clearance problem of the steering link with the oil pan. I cant find a clear answer, ive tried creeping through the swap pictures and i still cant find out how other people do it. ive been "working" on my project for the past 4 years and cant seem to get any progress, maily becasue i travel a lot. Quote Link to comment
hobospyder Posted January 10, 2017 Report Share Posted January 10, 2017 I think it was a truck but a guy who did either vg30 or vg33 ended up fabbing an oil pan out of like 3 oil pans Quote Link to comment
q-tip Posted January 10, 2017 Report Share Posted January 10, 2017 Try to find some pictures of the oil pan the experimental engineering (vg30.Com) makes, I do think k ow if Dave has the site up any more but you can also try to find Dave Carroll on facebook. Quote Link to comment
Lockleaf Posted January 10, 2017 Report Share Posted January 10, 2017 Flip crossmember, run a Nissan quest front sump oil pan and pick up tube. Or make your own. I modified an oil pan to fit in my build thread, "half pint - z22 swapped goon". I did it to install a z22, but the basic process should be the same if you're interested. Quote Link to comment
carterb Posted January 10, 2017 Report Share Posted January 10, 2017 Picturesof Dave's stuff here: http://datsun510.com/index.php?/gallery/album/260-experimental-engineering-parts/ 1 Quote Link to comment
q-tip Posted January 11, 2017 Report Share Posted January 11, 2017 Thanks Carter, I didn't know if the site was still up. Quote Link to comment
carterb Posted January 11, 2017 Report Share Posted January 11, 2017 http://www.vg30.com/is not on line but Dave Carroll may be contacted via facebook and I can help communicate when possible. --carter Quote Link to comment
Big_E-Dog Posted January 12, 2017 Report Share Posted January 12, 2017 or..........flip the crossmember and a front sump pan.... Quote Link to comment
