1983 Datsun 200sx rear axle into 1981 Datsun B310
  • Please log in to reply
12 replies to this topic
#1 Javi_Mayne
Javi_Mayne
    Newbie
  • Members
  • Pip
  • 27 posts
  • Cars:1981 Datsun B310
Posted 07 January 2017 - 07:07 PM
I have a '83 Datsun 200sx rear axle with disc brakes and I am going to put it into my '81 B310 I know I will have to change the driveshaft. But I was wondering what else do I have to worry about? I currently have the stock axle on my B310 with drum brakes.
[/URL]">http://20161025_142013_zpsn3f7gzf5.jpg
#2 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,302 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 07 January 2017 - 07:23 PM
The drive shaft flange is almost certainly different, and overall width slightly wider..
Can you measure WMS to WMS?? for me? wheel mounting surface? where the rim touches the drum?
I so want to do this swap some day into my 710.
Posted Image
#3 flatcat19
flatcat19
    Back in Black
  • Senior Member
  • 19,947 posts
  • Cars:Smaller. Better. Slower. Lower.
Posted 07 January 2017 - 07:53 PM
Bolts in. Slight bending of things to get the brakes hooked up.
Think about a different master cylinder for brakes now that you're eliminating the drums.
You want to do the whole swap? Or just swap the axles/backing plates over to get the disc brakes?
You can't hang if your nuts haven't dropped...it's physics
#4 Javi_Mayne
Javi_Mayne
    Newbie
  • Members
  • Pip
  • 27 posts
Posted 07 January 2017 - 07:58 PM
I want to do the whole swap. Is there any master cylinder you recommend?
#5 Javi_Mayne
Javi_Mayne
    Newbie
  • Members
  • Pip
  • 27 posts
Posted 07 January 2017 - 07:59 PM
My 13s didn't fit, the rim touches the drum right away the distance between the two is about an inch.
#6 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 07 January 2017 - 08:33 PM
I wants it all. wms to wms. Pretty sure it will be damn close to the goon axle.
Posted Image
#7 flatcat19
flatcat19
    Back in Black
  • Senior Member
  • 19,947 posts
Posted 07 January 2017 - 08:35 PM
You don't need a different master. Wouldn't be a bad idea either though.
First one I would look for, obviously, would be one from a 200sx. 81-83 280zx would be my next thought.
Match that rear end with a set of 280zx front struts for a level of awesomeness you can't handle.
#8 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 07 January 2017 - 08:43 PM
The zx is IRS, .....810 and Maxima wagon had solid axle but drums..
Posted Image
#9 Javi_Mayne
Javi_Mayne
    Newbie
  • Members
  • Pip
  • 27 posts
Posted 07 January 2017 - 08:51 PM
I was thinking of installing zx struts with T3 "big brake kit". Also Some are saying I will need a proportional valve for this swap. Is this true?
#10 flatcat19
flatcat19
    Back in Black
  • Senior Member
  • 19,947 posts
Posted 07 January 2017 - 09:44 PM
??? Nothing to do with discussion.
Zx is is rear disc brakes. With better brakes and struts on the front...As suggested above.
Go reread.
Prop valve or different master cylinder. See where we're going with this?
Big brake kit is overkill. OE zx brakes are adequate even with lots of power.
Save the money for rims.
#11 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 07 January 2017 - 10:35 PM
Go reread.
Hey, ....you're the master.
Posted Image
#12 flatcat19
flatcat19
    Back in Black
  • Senior Member
  • 19,947 posts
Posted 08 January 2017 - 12:07 AM
I didnt imply to mate the front struts to the rear end...
Could you imagine the thread that would create.
I think OP knew what I meant. But datzenmike.net had to be so literal about it though.
Bowing out. Thanks for that, oh wonderful moderator.
#13 datzenmike
datzenmike
    KING RAT
  • 70,302 posts
Posted 08 January 2017 - 07:59 AM
The Maxima sedan also has that style of caliper but only '81 and on. The earlier look like the 620. What are you so cranky about?
Posted Image
