411 timing
Kenmataya
  • Replies 6
Are you checking it with old timer timing light or advance-able type??
Have you checked to see the timing mark ( on pulley ) doesn't show up on other side of timing chain cover,,,i changed a chain AND PULLEY once and it showed up on the drivers side somehow... Engine still ran completely normal so i'm not sure if it was chain or pulley.
Oh,, i thought you were asking not making a statement..    Yeah it's a bitch just make sure you mark timing mark tab on front cover and v in the pulley with a welding paint stick real good and use adjustable timing light so you can really jamb that sucker in there.
You might have guessed why one would repaint the fan a bright color like white or like my idiot friend did,,, paint florescent orange stripes on the end like a WW2 airplane.. It won't hurt less but at least you will see it coming.
I'm also assuming J1300??
