280zx coilover build issues...
  • Please log in to reply
9 replies to this topic
#1 mbunzel
mbunzel
    Advanced Member
  • Members
  • PipPipPip
  • 102 posts
  • Cars:2013 Tacoma, 1979 620KC, 1970 510
Posted 26 December 2016 - 05:59 PM
Hey guys went to build my coilovers today and hit a couple snags. I am using 280zx strut assemblies with the T3 coilover conversion kit, t3 camber plates, t3 tophats, and gabriel part# G44869 inserts. First off the inserts are to long for the strut bodies. When the inserts are in the bodies they sit flush but this dosent allow the gland nut to thread in. The second issue im having is the the t3 camber plate bearings inner diameter is to small for the diameter of the insert. It will go on to the threaded portion but that is it. It seems like the inserts are just wrong all together but i bought them based on insert guide info from this forum and the fact that they are 280zx factory replacements but dont fit the the strut assemblies has me lost. Anybody having any input on this?
#2 Ranman72
Ranman72
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 5,765 posts
  • Cars:68 datsun 510 2 door / 69 Datsun Roadster /05 350z / 08 f350 / 73 datsun 1200 coupe
Posted 26 December 2016 - 06:26 PM
possibly the wrong parts in the box that is labeled right
it happens more than you think
this is not necessarily the problem just a thought of what could be the problem
#3 mbunzel
mbunzel
    Advanced Member
  • Members
  • PipPipPip
  • 102 posts
Posted 26 December 2016 - 06:38 PM
Its a possibility.
#4 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 12,758 posts
  • Cars:1971 2 door 510, 1969 4 door 510, 2002 Tacoma double cab
Posted 26 December 2016 - 07:09 PM
I had an issue with the inserts being a little too long. I could thread the gland nut on just enough. There is a small riser welded to the bottom of my inserts. I may have grinded that off a bit.. don't remember. Sounds like you need different inserts I guess..
You might google the part number and see if they look like what you have.
View my 69 510 4dr Sedan - Build Thread
View my 71 510 2dr Sedan - Coming soon.
http://drakers.pl510.info
#5 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,359 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 26 December 2016 - 09:06 PM
I have a depth of insert tube measurement of  376mm for the 280zx strut.
Posted Image
#6 Dolomite
Dolomite
  • Senior Member
  • PipPipPipPip
  • 1,047 posts
  • Cars:1971 2dr 510, 1990 Supra turbo, 1970 MGB mutt job turbo
Posted 27 December 2016 - 07:28 AM
The 280zx inserts work a little different with the t3 camber plates. There's a bag of spacers and nuts that come with the camber plates. There's a nut that has a shank that fits inside the camber plate bearing and threads onto the zx insert, it looks kinda like a stock zx lug nut but with an open end if that makes sense. It seems like an odd design but I've never heard of one failing. If the nuts aren't in the bag of hardware or you have any of issues just email gabe at t3, they have great customer service.
Chrome door handles are under rated.
#7 mbunzel
mbunzel
    Advanced Member
  • Members
  • PipPipPip
  • 102 posts
Posted 27 December 2016 - 07:44 AM
It seems like the i might have the wrong inserts then because the body length of the ones i have it slightly over 15"
Yeah i do have the bag of spacers and the one your referring to is the only one that i actually fits tight enough but the threads dont seem to be right. The threads on the insert are 1.5 and i cant tell what the ones on the nut are but they dont wanna go easy.
Does anyone have any recommendations for different inserts that maybe are a better fitment?
#8 datzenmike
datzenmike
    KING RAT
  • 70,359 posts
Posted 27 December 2016 - 07:49 AM
Any that are slightly short. Then build up the difference under them with washers.
Posted Image
#9 Dolomite
Dolomite
  • Senior Member
  • PipPipPipPip
  • 1,047 posts
Posted 27 December 2016 - 09:54 AM
I have tokico illumina 5 way adjustable inserts, they're about $150 each but definitely worth the price. I've had a set for over ten years and they're still like brand new.
#10 scooter
scooter
    Member
  • Senior Member
  • PipPipPipPip
  • 776 posts
  • Cars:77 200sx, 2015 fz09
Posted 01 January 2017 - 04:46 PM
Illuminas are sweet, id like to go for a ride in a car with the koni race inserts though.
