B210 Steering Coupler
  • Please log in to reply
5 replies to this topic
#1 az_rat210
az_rat210
  • Members
  • PipPipPip
  • 298 posts
  • Cars:1975 B210 Rolling Project (always something to do)
Posted 08 December 2016 - 08:15 PM
I think my steering coupler has worn out (goes between gearbox and steering column).  Unable to locate a new one on the web.
Anyone know if a steering coupler from a different datsun vehicle will fit?
Thanks in advance.
Entropy is the Enemy of Everything!
Being a Smartass requires avoiding Brainfarts, otherwise one becomes a Dumbass.
#2 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,571 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 09 December 2016 - 06:48 AM
Rag joint?? Looks like circular rubber?
Posted Image
#3 Icehouse
Icehouse
    wolf man
  • 5,782 posts
  • Cars:57 VW SC - 59 210 - 64 VW camper - 2 68 510 2 dr - 70 bluebird coupe - 3 71 510 2 drs - 73 1200 ute
Posted 09 December 2016 - 11:33 AM
Might try a 510, they share the LCA's, TC rods, tie rods and almost the same crossmember.  Worth a shot.
"People don't like it when shit doesn't match their rule of thumb."    Sam
#4 datzenmike
datzenmike
    KING RAT
  • 72,571 posts
Posted 09 December 2016 - 01:57 PM
The 510 uses a small U joint somewhat like those used on the 720.
The B-210 rubber coupling (or rag joint) is also common to the '77-'80 810, '77-'79 S10 (first gen 200sx) and the '80-'83 S110 (second gen 200sx).... same part.
If you mean something else say so.
Posted Image
#5 az_rat210
az_rat210
  • Members
  • PipPipPip
  • 298 posts
Posted 11 December 2016 - 10:52 AM
Thank you for the information.  It is greatly appreciated.
Now I just have find one.
It is a rag joint style.  Between the column and gear box.
#6 datzenmike
datzenmike
    KING RAT
  • 72,571 posts
Posted 11 December 2016 - 02:35 PM
I made one once out of 3/8" thick rubber conveyor belt. Just used a drinking glass to draw the circle and drilled 4 holes for the bolts. It's still on the 620. It had a mixture of 720 column and D21 power steering box. The bolt patterns were not the same.
Posted Image
