rinigado Posted December 4, 2016 Report Share Posted December 4, 2016 This weekend, I'm getting a start on sorting out all the problems that accumulate after the 22 years that my 240z has sat without running. First up were my stuck rear wheels. I spent some time this afternoon pounding, heating and prying the first of the brake drums off (driver's side). I ran out of daylight to work on the other side, so that's a fun job for tomorrow morning. Now, I've put the drum back temporarily until I can get some new shoes. To do so, I had to turn the adjuster wheel on the wheel cylinder all the way back in to get the shoes pulled in enough to get the drum back on. I'm nervous about what the fit when I put in new, thicker shoes! Next step will be to find some new shows, and turn the drums to get them cleaned up. Turns out the PO had a second set of brake drums shipped to him from someone, and they were sitting in a box inside the car. They're used, but I'll get both sets measured and pick the best pair. And I'll need to start replacing some cracked brake hose sections. I'm sure there's more once I check more of the car, but the rear hoses for sure need replacement. Regarding the drum wheel cylinder, is there a good way to test the cylinder, or should I just wait and see if the parking brake holds rear brake tight? I'm guessing it's probably also not a bad idea to buy a new set of springs and clips for 15 bucks while I'm in there in case the return spring is a little tired. Quote Link to comment
datzenmike Posted December 4, 2016 Report Share Posted December 4, 2016 Replace the cylinders, they might easily begin to leak next week, next month. Be sure the mechanical adjusters are backed all the way off and the emergency brake is not only off and the adjuster loosened, but that the e brake cable is not rusted within the sheath and not releasing. 2 Quote Link to comment
rinigado Posted December 4, 2016 Author Report Share Posted December 4, 2016 in the case of the wheel today, the parking brake cable was disconnected from the wheel cylinder lever, so it seems like it was a combination of things just being seized together, and the wheel cylinder not being turned all the way in. Hopefully it'll only take about half a million whacks with a hammer tomorrow to get the other side off. I'll add a pair of wheel cylinders to the growing rock auto shopping cart. Quote Link to comment
MikeRL411 Posted December 4, 2016 Report Share Posted December 4, 2016 in the case of the wheel today, the parking brake cable was disconnected from the wheel cylinder lever, so it seems like it was a combination of things just being seized together, and the wheel cylinder not being turned all the way in. Hopefully it'll only take about half a million whacks with a hammer tomorrow to get the other side off. I'll add a pair of wheel cylinders to the growing rock auto shopping cart. For longevity, use a plastic shot filled "dead" hammer, not an iron headed hammer! One of the white rubber hammers is a good second bet. Hammering with an iron hammer can crack the drum. Check to see if the drums have tapped holes to use bolts to lift the drums away from engagement [spoken from ignorance as to 240Z drum characteristics]. Quote Link to comment
rinigado Posted December 4, 2016 Author Report Share Posted December 4, 2016 yep, I was using a softer hammer after seeing that advice on some older threads around here. Unfortunately there weren't/aren't any extra holds to help pull the drums off. Quote Link to comment
datzenmike Posted December 4, 2016 Report Share Posted December 4, 2016 You could try heating them also. Makes the hole around the axle larger from expansion. Quote Link to comment
flatcat19 Posted December 4, 2016 Report Share Posted December 4, 2016 HF sells big jaw pullers. That's what I used to remove the drums on my 521. May need a 3rd or 4th hand to hold the jaws as you tighten the bolt. If doing brake work on an unknown system...just replace all of it. Brake parts are not all that expensive through rock auto. Peace of mind isn't as expensive as one would think. I replaced every bit of my brake system for less than $250(all 4 wheels.) I machined my own drums, bent my own hard lines, rebuilt my adjusters and replaced everything else. Springs, cylinders, hoses, shoes, clips. Quote Link to comment
datzenmike Posted December 4, 2016 Report Share Posted December 4, 2016 I don't know about the Z car drums but most others have two threaded holes across from each other. Takes a 10mm? head metric bolt. Tighten in the bolts and they bottom out on the axle flange beneath the drum and force the drum out and off. Have a care! They are only small and you can strip them. In addition they can also tear the anti rattle pins out of the backing plate if the shoes pull outward too. I tighten the bolts and then hammer around the outside of the rim to loosen what will loosen, and then tighten up any slack and repeat. Slowly the drum moves outward and the shoes are exposed. I did have a really old drum that just had to come off. Everything e brake and shoes seized to hell. I tightened and slowly tore the shoes and all right off the backing plate. Quote Link to comment
rinigado Posted December 5, 2016 Author Report Share Posted December 5, 2016 got the second drum off today. I wasn't as lucky on the positioning of the little access hole on the 2nd drum..it wouldn't turn at all and the hole was nowhere near the wheel cylinder adjuster, so no chance to back off the wheel cylinder. Some heat and pb blaster and hammering, same as before, but this one only took about 100000 whacks to get it done. A relative piece of cake compared to yesterday! Unfortunately, at least on my brake drums, there are no extra holes to put a bolt through to push the drums out. You'd think they would have figured out to put a hole on the back plate to get at the wheel cylinder. As far as replacing the works, I was thinking the hard lines would likely be ok, but is the consensus that it's worth replacing those as well? Quote Link to comment
flatcat19 Posted December 5, 2016 Report Share Posted December 5, 2016 Hard lines should be fine. I left the main line in mine. The reason I replaced lines was because of stripped flare nuts or kinks in the lines. Quote Link to comment
rinigado Posted December 27, 2016 Author Report Share Posted December 27, 2016 is there anything to be careful of when taking the aluminum drums to a shop to be resurfaced? I assume the inside surface of the brake drum is still a steel/iron liner? I had one shop tell me they couldn't turn an aluminum drum, so wondering if there's any trick to working on these? Quote Link to comment
flatcat19 Posted December 27, 2016 Report Share Posted December 27, 2016 The inside lining should be steel. Place a magnet on it to verify. Take them elsewhere to have machined. And don't tell the monkey at the counter that they're aluminum. Just that you want your drums machined. 1 Quote Link to comment
rinigado Posted December 28, 2016 Author Report Share Posted December 28, 2016 I found a brake guy that's cheaper and should get it done no problem. I'm gonna take the drums and rotors in tomorrow to him to get them cleaned up. One of the boxes of stuff that came in the car had a pair of similar rotors. They don't look exactly like the ones I pulled off, but overall dimensions are the same, and the brake surface still has more thickness. The raised hat section has a bit of a different profile with some cutout sections. The one on the left was pulled off the car. The one on the right is one of my new mystery rotors: Getting the rotors and hubs separated was a pain in the ass, but someone over on classiczcars forums posted something about using a cold chisel to drive in between the ends of the studs and the rotor surface, and working your way around the brake, slowly driving the pieces apart. That worked like a charm. Quote Link to comment
Ranman72 Posted December 28, 2016 Report Share Posted December 28, 2016 I found a brake guy that's cheaper and should get it done no problem. I'm gonna take the drums and rotors in tomorrow to him to get them cleaned up. One of the boxes of stuff that came in the car had a pair of similar rotors. They don't look exactly like the ones I pulled off, but overall dimensions are the same, and the brake surface still has more thickness. The raised hat section has a bit of a different profile with some cutout sections. The one on the left was pulled off the car. The one on the right is one of my new mystery rotors: Getting the rotors and hubs separated was a pain in the ass, but someone over on classiczcars forums posted something about using a cold chisel to drive in between the ends of the studs and the rotor surface, and working your way around the brake, slowly driving the pieces apart. That worked like a charm. just double check the backspace on the rotors the early stock rotors have the slots you see the aftermarket ones might not but the 280z had a different offset and no slots either Quote Link to comment
