Shaker Posted November 30, 2016 Author Report Share Posted November 30, 2016 @ G-Duax - Haha yeah a few seconds into reading about those jam blocks I was laughing. I`m sure if your looking for pain and agony they would be the way to go hahaha. Thanks for the information on the LSD. Quote Link to comment
Lockleaf Posted November 30, 2016 Report Share Posted November 30, 2016 Fyi - h190 lsd are uber rare and usually very expensive. They can occasionally be found in 2wd hardbody trucks at the junkyard, but very uncommon there as well. Quote Link to comment
G-Duax Posted November 30, 2016 Report Share Posted November 30, 2016 I import them......and a lot of other LSDs But yes, the H190 is still hard to find in Japan. Quote Link to comment
Shaker Posted December 1, 2016 Author Report Share Posted December 1, 2016 Looks like an alright deal for what's included with it - you'll of course have some adjustments with the exhaust and wiring ect. You can find the link for wiring boxes here: http://community.ratsun.net/topic/28097-canam-production-easy-wiring-boxes-for-efi-works-for-kas-srs-vgs-cas-and-more/?st=0 Only thing I'd mention is the SR20/KA stock transmission is going to be longer than stock by approx 2 inches. You'll have to account for this during your installation and positioning of the shifter as well as the driveshaft. I think I sent a reply to the right person on picking up the wiring box if possible if not then its the Wiring Specialties and Haltech ECU $$$$ 1 Quote Link to comment
thisismatt Posted December 1, 2016 Report Share Posted December 1, 2016 I import them......and a lot of other LSDs But yes, the H190 is still hard to find in Japan. Saw the one you had on ebay - looked nice! Question, if you know - how do 8" toyota LSD's compare to nissan H190 LSD's? 1 Quote Link to comment
G-Duax Posted December 1, 2016 Report Share Posted December 1, 2016 Totally different, or I would have put that 8" torsen into my truck...... I'd sell my left nut to have a helical in the Datsun, but the only way that will happen if I put a Toyota axle under it, and that's not going to happen either. There were a few Quaife helicals made for the H190 axles, but from what I have heard of the years is that one guy in Australia is hording them all, and won't sell for any reason. I don't have enough free cash to call Quaife up, and have them make another, and the last I heard, they don't accept old nuts in trade. 1 Quote Link to comment
thisismatt Posted December 1, 2016 Report Share Posted December 1, 2016 I meant more from a usability/quality standpoint. Toyota CLSD vs nissan CLSD 1 Quote Link to comment
G-Duax Posted December 1, 2016 Report Share Posted December 1, 2016 Pretty much the same inside if comparing to the TRD LSD. But the 8" from the Supra doesn't have the ramps like the Nissan/Nismo/TRD does, that forces the plates tighter together when torque is applied. It just uses a single spring for pressure, and is kind of wimpy in stock form. If I remember correctly, the stock torque figure is 45 ft/lbs break away, and then they go down hill from there, as they wear. I played with heavier springs, double springs, and was able to get one up around 100 ft/lbs, Now Weir Performance sells spring kits & such for them, but they will never bite as good as one with the cams/ramps in them. 1 Quote Link to comment
Shaker Posted December 3, 2016 Author Report Share Posted December 3, 2016 There are plenty of engine importers in Vancouver. CDN dollar doesn't buy much in the US. Be sure to get the transmission, ECU and the wiring for it. Both S13,S14 and S15s had DET options but the S15 would have more improvements. Have you considered the KA24E from a 240sx? Do you know the names of any of these importers? I`m not from the area not even close haha but I am here now in Vancouver until Dec 11th when I drive to NB. Would like to pick up my engine here or along the way. I have a couple places that are possible but getting one here would be great. Cheers :) Quote Link to comment
Shaker Posted December 10, 2016 Author Report Share Posted December 10, 2016 Looks like an alright deal for what's included with it - you'll of course have some adjustments with the exhaust and wiring ect. You can find the link for wiring boxes here: http://community.ratsun.net/topic/28097-canam-production-easy-wiring-boxes-for-efi-works-for-kas-srs-vgs-cas-and-more/?st=0 Only thing I'd mention is the SR20/KA stock transmission is going to be longer than stock by approx 2 inches. You'll have to account for this during your installation and positioning of the shifter as well as the driveshaft. Just sent the order for the Wiring Box. :) Quote Link to comment
Shaker Posted December 23, 2016 Author Report Share Posted December 23, 2016 Ordered an S13 SR20DET today from jdmsource.com out of Calgary, AB. Comes with all the fixings. Will take some pictures once I get it to the Shop. Quote Link to comment
Shaker Posted January 6, 2017 Author Report Share Posted January 6, 2017 old images 2 Quote Link to comment
Shaker Posted January 22, 2017 Author Report Share Posted January 22, 2017 Well People, Here is an Update to the parts I`ve gathered together for the Build. JDM Nissan SR20DET S13 Black Top Complete w/5 Speed Transmission B&M 45088 - Manual Shifter Precision Sport Shifter ARP SR20DET Flywheel Bolt Set Complete Belt Set SR-S13 OEM Timing Chain Kit Coolant Temp Sensor OEM Clutch Master Cylinder Nissan 240sx 89-98 Genuine Nissan OEM Oil Filter 15208-53J0A x2 ISR Performance Adjustable Engine Mount Set OEM Trans Mount OEM Front Main Seal OEM Rear Main Seal Mishimoto Radiator Package w/Dual Fan OEM 300zx Fuel Filter OEM Water Pump SR20DET Megan Racing Stainless Steel Downpipe 3" Megan Racing Silver Pulleys MagnaFuel FPR Kit Megan Racing Turbine Outlet Walbro 255 LPH Fuel Pump Intercooler Hotpipe w/HKS BOV Flange OEM Coolant Temp Sensor Red Cam gears SR20 DNMTMSR20DETT T3W Turbo manifold SR20DET w/ T3/T4 flange 38mm eastegate flange EXD06950B Stage 2 cerametallic clutch kit S13S14S15 w/ SR20 FDZ143221 Fidanza flywheel S13S14 w/ SR20 MMODP12125B mishimoto magnetic oil drain plug NIS ClutchSlave clutch slave cylinder 240SX YMGK009 gasket kit 91-99 SR20DET Datsun Wiring Box Will post pics when I get started working on the Project in April 2 Quote Link to comment
Shaker Posted January 23, 2017 Author Report Share Posted January 23, 2017 Anyone have a Muffler recommendation? Quote Link to comment
Crytek89 Posted January 24, 2017 Report Share Posted January 24, 2017 Anyone have a Muffler recommendation? For my own I picked up a 2.5in Borla straight-through - you're probably going to want to increase the diameter of the exhaust by a bit anyway. It was certainly a bit more expensive that stock at $160 coming from the states but once I install I think I'm going to be pretty happy with it. Quote Link to comment
paradime Posted January 24, 2017 Report Share Posted January 24, 2017 Well People, Here is an Update to the parts I`ve gathered together for the Build. JDM Nissan SR20DET S13 Black Top Complete w/5 Speed Transmission B&M 45088 - Manual Shifter Precision Sport Shifter ARP SR20DET Flywheel Bolt Set Complete Belt Set SR-S13 OEM Timing Chain Kit Coolant Temp Sensor OEM Clutch Master Cylinder Nissan 240sx 89-98 Genuine Nissan OEM Oil Filter 15208-53J0A x2 ISR Performance Adjustable Engine Mount Set OEM Trans Mount OEM Front Main Seal OEM Rear Main Seal Mishimoto Radiator Package w/Dual Fan OEM 300zx Fuel Filter OEM Water Pump SR20DET Megan Racing Stainless Steel Downpipe 3" Megan Racing Silver Pulleys MagnaFuel FPR Kit Megan Racing Turbine Outlet Walbro 255 LPH Fuel Pump Intercooler Hotpipe w/HKS BOV Flange OEM Coolant Temp Sensor Red Cam gears SR20 DNMTMSR20DETT T3W Turbo manifold SR20DET w/ T3/T4 flange 38mm eastegate flange EXD06950B Stage 2 cerametallic clutch kit S13S14S15 w/ SR20 FDZ143221 Fidanza flywheel S13S14 w/ SR20 MMODP12125B mishimoto magnetic oil drain plug NIS ClutchSlave clutch slave cylinder 240SX YMGK009 gasket kit 91-99 SR20DET Datsun Wiring Box Will post pics when I get started working on the Project in April I just saw your thread for the first time tonight and just read threw it. As I was reading I had my fingers crossed that you didn't buy the s14. Not a bad motor by any stretch but VVT system and the low port intake make it harder to upgrade. The s13 blacktop is the newest of the simpler high port SR20 design and has better bang for the buck in terms of power potential. I researched the hell out of SR platform before putting a Blk top s13 in my 510. Your parts list shows you're serious about this build. :thumbup: I don't know if you're considering it, but I highly recommend getting a Wiring Specialties harness. That being said, I will admit the wiring is not my strong point, so I lean towards the easier the better. Best of luck on this build, I look forward to watching 1 Quote Link to comment
Shaker Posted January 24, 2017 Author Report Share Posted January 24, 2017 @ paradime - Yeah I kept going back and forth on what SR I would go with. Google and I are well acquainted lol. When I was talking to the Shop I bought my engine from he told me about the VVT in the newer SR's and warned me about the harder overall swap and setup is, I think I will be quite pleased once I get this one in and Running. I`m 100% considering the wiring harness from Wiring Specialties but if I go that route I will upgrade the ECU and other parts at the same time just so I can order the harness with prefab connections. @Crytek89 - I was looking at the Borla site last night and was wondering how they sounded on a Nissan. Maybe you can post a video before and after install to hear the difference. Cheers & Thanks for the Input :) 1 Quote Link to comment
paradime Posted January 24, 2017 Report Share Posted January 24, 2017 Upgrading the ECU, I'm intrigued. Were you thinking a stand alone maybe? I'm running a Link G4 plug in and it has been amazingly adaptive and stable. As for exhaust I have a 14" Magnaflow with 3" pipe. It's not a discrete sound, so may not be a good choice if you're using it as a daily driver. I have miked video right at the tail pipe if you're interested. 1 Quote Link to comment
Shaker Posted January 25, 2017 Author Report Share Posted January 25, 2017 I`m always interested in clips haha. As for the ECU I`m going to go with a Haltech Elite 1500 with the Wiring Specialties Harness and a RacePak digital dash. 966 USD for the Harness about 1500 USD for the Haltech so that will have to wait for a at least 2 pays, Lots of work prior to do anyway. Currently before I drop this engine I`ve decided to change out the front suspension/Steering components for a Mustang IFS. So the Craigslist, Kijiji Etc Search is on to find an old Mustang ii someone is selling on the cheap because I plan on swapping the rear end for a ford 8.8 or 9" as well, Which brings me to a question - Does anybody know the width (Track Width) of the rear axle on a 720 from inside to inside (Drum to Drum)? The measurements I have is - track/tread (front) 1310 51.6 track/tread (rear) 1350 53.1 length 4365 171.9 width 1610 63.4 Thats a sweet 510 you have I`ll have to sit down and read through your thread, Nice video though. 2 Quote Link to comment
Lockleaf Posted January 25, 2017 Report Share Posted January 25, 2017 The best, most common manner of measuring width of an axle (or independent suspension setup) is wheel mounting surface. 720 is about 56.25 inches wms. 3 Quote Link to comment
paradime Posted January 26, 2017 Report Share Posted January 26, 2017 You will like the Haltech, it has lots of cool gizmos. I think you can get the harness cheeper. FR Sorts has the universal SR20det motor and trans harness for $388. Are you having them modify it for you? Even then that seems kind of steep. Exhaust note is at about 6:38 That's about 6000 rpm. At 7500 it sounds a lot like a sport bike. Again, not a discrete sound. https://youtu.be/GZtp6PiFlTI?t=6m40s 1 Quote Link to comment
Shaker Posted January 27, 2017 Author Report Share Posted January 27, 2017 A shop I`ve bought some parts from already suggested this combo http://vibrantperformance.com/catalog/product_info.php?products_id=857 vibrantperformance.com/catalog/product_info.php?cPath=1527_1032_1109&products_id=50&osCsid=3d7593682da7f66a0337c85dbed0c5e7 I haven't used a Vibrant since I was 16 with a Mazda Mx-3 V6 so any advice would be great. I`m sure why it says not to use the Cat on a turbo engine hence part of the reason I`m asking. 1 Quote Link to comment
Turbosauce74 Posted February 14, 2017 Report Share Posted February 14, 2017 So glad I found this thread. Pretty much what I'm planning to do. Keep it up 1 Quote Link to comment
Crytek89 Posted February 14, 2017 Report Share Posted February 14, 2017 @Crytek89 - I was looking at the Borla site last night and was wondering how they sounded on a Nissan. Maybe you can post a video before and after install to hear the difference. I should have my Borla installed by March - still waiting on my friend to install. His work has slowed down a bit so should be getting close to that soon. I dunno about before/after though.. my current muffler looks like a grenade went off inside it :angel: 1 Quote Link to comment
Shaker Posted June 20, 2017 Author Report Share Posted June 20, 2017 Hey Everyone, Update is that the motor is going in over the next couple weeks. The wiring harness arrived as well. I`ll post some pictures once its in. Right now I`m looking at picking up an Intercooler and Pipe kit. See ya soon! 2 Quote Link to comment
