A 521 in Massachusetts
Crashtd420
  • Replies 5.1k
You guys need something like the big brass summer/winter" valve that the roadsters use on their heater core circuit. Mine is permanently bypassed, since I only drive the car in nice weather anyway. It's part of the SU heating circuit.
They're expensive and rare.
http://www.kendo-usa.org/datsun/manifoldvalve.pdf
I'd buy that. Or if someone could 3D print one.
Are you referring to the cover plate on the front of the blower that is rubber and connects to the upper vents? That's a part that basically cannot be rigid, so 3D printing it is out of the question.
What may be possible, is to 3D print a mold, and then use that mold to pour urethane or even silicone. It's not an easy process.
GM uses a heater bypass valve on most of their LS engines. Those are cheap and basically do what you have described, but they have two heater hose sizes on them. 3/4 and 5/8. You would have to neck the larger one down.
https://ls1tech.com/forums/attachments/conversions-hybrids/248925d1282234339-bypass-type-heater-valve-late-chevy-heater-valve-4-seasons-74781.jpg
It creates heat in the cab.
Turning on the heater to help cool the engine is a trick that goes back, way before I was born!  It acts an an additional radiator.  It's even made it into movies when people are driving across Death Valley or climbing the Grapevine hill.  Better to suffer the extra heat inside the car than to overheat the engine.  It's a bit drastic, but it definitely works.  I've used it 5-6x's in my life.  It was a fairly common practice back when all cars used mechanical fans connected to the engine.  It was taught to new drivers just like changing a tire used to be taught.  More modern cars are way more efficient at cooling the engine these days.  There's your boring fact for today kids. lol
Added this to the system today....
Oil pressure cutoff for the electric fuel pump..... supplies power during crank And once the motor has oil pressure.. once engine shuts off so does the fuel pump...
Also got my electrical back to functioning with all my switches so I can start the truck again.
Master on... start button is in the little black box...
And ummm these are my extra switches...
Left is dizzy, ignition, acc, gauges...
Also got a backup R light ...
Couple extras for possibly fog lights or what ever else I might want a switch for.
Two on the right are fan and fuel pump overrides , with indicator lights so I know if they are on ...
Dome light,top left
Led override, top right. override is for all the switches if I don't want the lights on.... and the horn button...
next step is running the wiring to the headlights, parking lights and horn up front.... and I still need to hook up the wiring in the rear to the lights, it's back there just nothing hooked up yet.....
Needs more switches
Ya... I'm a little wierd with the switches...
In the end there maybe one more.... I wanna do a battery disconnect and put that and the fuse block inside the glovebox but that will be later....
And mainer. . I actually like figuring out the wiring.... once it's functional then I'll clean it up a bit.... to do that will probably be a winter project where I pull the complete harness.... eventually I want to replace all the old connectors and shorten some more wires. And a bunch of other stuff to clean up the wiring...
If I was mocking up switch placement I probably would have used stickers.
Drilling the hole seems like your mind is pretty made up about their permanent location. Well past the mock up phase.
I get what your saying.... I guess the mocking up now was more about the wiring not the location of the switches in the dash....
Either way....
Merry Christmas to everyone here....
I like to put battery disconnects in vehicles that don't get driven a lot. If you install it under the dash or under the seat, it can act as a simple security device as well. Beware though, the ones you buy at your local auto parts store are usually only good to about 20 amps. A starter draws more than that. Summit has a complete lineup of disconnects that range all the way up to about 300 amps. - https://www.summitracing.com/search/part-type/battery-disconnect-switches/switch-actuation/rotary-turn?N=4294944883%2B4294944881&SortBy=Default&SortOrder=Ascending&tw=battery%20dis&sw=Battery%20Disconnect%20Switches
Don't waste your money on the plastic bodied switch. They are flimsy and don't last long.
Merry Christmas!
Ya I've seen the various ones..... I definately want something better than the 5.95 special....
And the starter isn't in that part of the wiring where I wanna put the disconnect.... I have the fuse panel in the cab so it will be between the power cable coming in to the cab and the fuse panel....
I found this one which is a 185 amp and has a key....
I wouldnt mind having some sort of a key for exyra security, since I have no ignition key... but i do have the ability to lock out the dizzy with my phone app... one of the reasons I bought it...
