A 521 in Massachusetts
Crashtd420
  • Replies 5.1k
2 steps closer....
got the heater core plumbed in and control valve installed...
I now have heat...
Not sure where I will mount the pull cable
Yet .... but that's minor...
I also have a functioning windshield washer sprayer now.. (never had one).. used one of those universal bags for now... actually works pretty good...
Also I finally have someone coming by tomorrow to help install the windshield and back window. Should be able to install the wipers and rear view too before we are done....
And my friend doesn't know it yet but I am hoping to test fit the doors and fenders and get him to help me with the gaps...
I only have a few items left on my list of things to do before I have to paint...
Paint what?
The whole truck like they did at the factory, my truck lost a windshield, when they replaced it they mentioned that the paint under the seal was great and I had no rust under it, they thought they would find rust holes, you cannot paint there once the windshield and rear window are in.
The entire cab was stripped and then coated with por15 and then painted with a single stage urethane....
I think it will be ok....
Do you have new side window felt? I’m trying to find some. There’s a missing chunk in my driver’s side and it whistles going down the road.
Ya I have some new felt.... I couldn't tell you where I got it from. Or even how good or bad it is. it's been a couple years since I bought that...
I've been crossing my fingers every time i go to install one of the seals I bought off eBay so far so good... I just go with who ever has the best rating for what I want and hope for the best.
You were talking about the channel around the whole window right?
Ya it's all from Thailand....
If you ment the ones that run across the bottom of the window.. those are a bit different... check the measurements and spacing of the clips.. I almoat bought some listed for the 521 the was a few inches to long... I think i orders those and the wing window rubber out of Australia....
You can find the channel felt a few different places.  I have some of the Thailand stuff and it has been fine, although something doesn't quite seem right with my driver side...like the glass is too narrow or the felt is "too far" in.  Basically, the glass can move front/back and there's always a little bit of a gap.  Originally my channels had an extra piece of chrome channel RTV glued in...I thought maybe the glass had been reground, but haven't had it out next to another piece to check yet.
You'll want to pull the glass to replace the felt...it's a bit of a process but not too difficult.  I used some 3M adhesive you can buy from your LAPS to install it.
I use 510 channel felt in my 521s when I can find it cheap enough, I use early Datsun Roadster felt on everything else, it is expensive but that shit is awesome, there are no leaks with that stuff as when you roll the window down the inside portions come together and touch each other, and when you roll the window up it spreads apart again and makes a good seal.
Made good progress today.. front and back windows are in... seals fit really good so I got lucky there....
Apparently didn't take a pic with the wiper arms on... but wipers are on...
Also glued a puck in place on the windshield to mount a rear view mirror... maybe later I'll spend the money on a correct one later....
Oh also found this...
Hung it up in the garage...
Just some pics of the wipers and mirror...
the wipers arms were painted black semi gloss, I think I need some new blades. Ones I had seem a bit old.. I probably installed them 15 years ago..
In order to make the mirror work I mounted it upside down and was able to rotate the mirror so the day/night lever was still on the bottom....
Well the weather is getting tolerable... mid 40s after work means I can get stuff done .... I generally get an hour after work a couple days a week to get work done on the datsun before I gotta get inside to the family...
Well today i smoothed over the holes
and welded some bolts into the buppertettes...
I was hoping they would be a little tighter to the lights and bottom of the bed but there they are... good enough for inspection...
I do have some room on the bracket.... I still might slot the bolt hole and then I can probably get them atleast an 1/8 or so closer....
I got a set of taillights for you. In really good shape just had the frames powder coated, lens are good and back housings have a lot of life in them.PM me i might part with them.
I appreciate the offer...
i actually eventually wanna do a roll pan back there and maybe flush some round lights into it.
Right now I'm just trying to use what I have to get back on the road And then I can modify and upgrade from there...
