Info on fuel injection for my z22
  • Replies 3
The parts physically bolt up. But you still have wire up everything and install a higher pressure fuel pump.
I believe Spiff is running a z22 with swapped on efi. He would be a good source of info.
Need the O2 sender exhaust manifold and the Z22E head has a water temp sensor (not sender like for the gauge) in it beside the #1 plug... this won't be on the Z22S engine. May have to swap the head also. The temp sender lets the ECU know at what stage the engine is during warm up to set the correct richness. Without it it will run like the choke is on.
This guy is doing a Z22ET but the EFI conversion would apply.... http://720world.com/forum/topics/how-to-build-a-z22et
  • 3 years later...
