datzenmike Posted October 10, 2016 Report Share Posted October 10, 2016 Maybe very small vacuum leak. Carb bolts tight? any vacuum lined directly connected to the intake loose or cracked? Quote Link to comment
Jelmer C31 Posted October 10, 2016 Author Report Share Posted October 10, 2016 Worked on the Laurel again. I checked the ignition timing with my timing light and it was at 2-3 degrees! So I set it at 10° like my FSM suggests for the L20a and L24. I didn't touch the choke yet because I want to see what it does with this timing setting. If it still has a hickup when cold I will put it 1 setting richer. Tomorrow evening maybe the idle mixture setting like you descriped Mike! And maybe this weekend the valves. Make it run better and better is fun to do! Quote Link to comment
datzenmike Posted October 10, 2016 Report Share Posted October 10, 2016 2-3 degrees is way, way, retarded. This will ad tonnes of torque and go power. Try a notch richer but be prepared to add several more to get it right. Quote Link to comment
banzai510(hainz) Posted October 10, 2016 Report Share Posted October 10, 2016 I always reck the timming as its simple and cheap. Sometimes be surprised how it can change. Maybe distributor is wearing abit. I cheak my timming and carb adjust every 6 months on my daily driver Quote Link to comment
Jelmer C31 Posted October 11, 2016 Author Report Share Posted October 11, 2016 I only have the car for a couple of month's and they previous owner never heard of maintanance..... This morning it did better when cold so maybe I adjust it a little bit tonight. Quote Link to comment
Jelmer C31 Posted October 20, 2016 Author Report Share Posted October 20, 2016 The carb is still doing fine! I idled high one time again but the throttle cable was to tight so after adjusting it runs great. Starts direct and runs strong! Quote Link to comment
