Alternator relocation?
Apollo77
77 620 pick up. I put a slightly larger alt in to accoutrements for the fact I'm nor in the 70s anymore, however it is more of a chore to get the damn thing in because of the lower coolant hose. And I max out a brand new and larger belt soon as it's in. Can I move it to the other side where the emissions pump is easily?
  • Replies 17
Exactly which alt u using? I have a 60amp z alt and fits find. Just a matter of finding right belt. Mine uses 36 in belt,but they make belts in half sizes.
It's not an easy fit, the idler arm is in the way underneath, and the rad hose, and the lower rad inlet casting on the timing cover. I fit a 60 amp car alternator to my 620 but used a 280z water inlet (it's bent more to the rear than the 4 cylinder ones) a 720  alt. block mount (it sits higher) and a shorter belt. This lifts the alternator up and away from the idler arm and moves the rad hose more out of the way. It still required that you put the belt on the pulley before bolting the alternator to the block mount. Eventually I had a 90 amp alt from a K car. All are a tight fit.
Maybe lower, I thought it was slightly higher than the 620 and this lifted the alternator away from the idler. But it was a long time ago.  Higher gave more room but now the lower rad hose where it enters the timing cover was closer and tighter. The Z car inlet is swept more to the rear and solved this.
As far as I know the top mount is an 85/86 alt. mount, see how the front alt. mount is lower than the top two mount holes.
The middle mount has the alt. mount above the two top mount holes, this one is early 720.
The bottom mount is from a 280Z car, it mounts the alt. lower also, but it also mounts the alt farther back, and the mount holes don't match the Z/L block mount holes.
When the alt. is mounted lower, it can be tilted more towards the engine, this allows one to use a shorter belt which moves it away from the idler arm.
It's all about that radiator hose clearance.
The big issue is the lower you mount the alt; the farther away from the block the lower alt. mount has to be, as the oil pump is in the way.
Also is there anyone that can help me with wiring? I just don't want to keep messing with this and if it's user error they will catch on. 4 wires going to the alt, two should be in a plug but are not, one is a ground as far as I can tell, and one is to battery. I just want to make sure they are in the right spots. I can send pix via phone if needed
Yes i use one long bolt on the bottom too, and theres a plate on both ends. Before i trimmed the chevy alternator long bolt hole into a tab and ran a short bolt, sometimes it would break the bolt, last time it broke the alternator casting so this setup was devised.
That is an l16 water pump with an inch spacer in between the water pump and the pulley. To make this work on a stock motor youd have to build that bracket an inch shorter, and have to get creative with the tensioner.
For your alternator you should have a big battery wire, ground, one will be switched power from your ignition for the alternator fields and the last one is for the idiot light. If you have a voltmeter or a light probe you should be able to figure it out
